14.04.2023, 09:12
I'm using this script in all of our projects to send a backup each month.
One of the LM5 can't send it anymore and got this in the logs
* string: connection refused
* nil
* string: Send Mail
NB: LM5 is connected to the ethernet.
What could be the issue?
* nil
* string: Send Mail
--*** For FW spaceLYnk 1.2.1 and FW homeLYnk 1.5.1 or higher ****--
--** Email backup as attachment created by Erwin van der Zwart **--
--********************* Start of parameters *********************--
--Gmail (smtp) username !IMPORTANT!
user = 'xxxx'
--Gmail (smtp) password !IMPORTANT!
password = 'xxxx'
--Sender for e-mail
from = '<xxxx>'
alias_from = 'From me'
--Recipient for e-mail
to = '<xxxx>'
alias_to = 'To you'
--Subject for e-mail
subjectpart1 = 'Back-up file'
subjectpart2 = 'xxx'
--Message on bottom of email (will only be showed when client don't understand attachment)
epilogue = 'End of message'
--******************** End of parameters ********************--
--********** DON'T CHANGE ANYTHING UNDER THIS LINE **********--
--Create table to include mail settings
local settings = {
from = from,
rcpt = to,
user = user,
password = password,
server = 'smtp.office365.com',
port = 587,
secure = 'tlsv1_2',
starttls = true,
--Create attachment
src = 'backup-' .. os.date('%Y.%m.%d') .. '.tar.gz'
dst = '/home/ftp/' .. src
-- prepare files for backup
os.execute('sh /lib/genohm-scada/web/general/backup.sh')
-- create cleanup archive
os.execute('cd /lib/genohm-scada/storage && tar -c -z -f ' .. dst .. ' ./')
--Create subject
subject = subjectpart1 .. ": " .. src .. " " .. subjectpart2
--Load required modules to send email with attachment
local smtp = require("socket.smtp")
local mime = require("mime")
local ltn12 = require("ltn12")
--Create e-mail header
settings.source = smtp.message{
headers = {
from = '' .. alias_from .. ' ' .. from .. '',
to = '' .. alias_to .. ' ' .. to .. '',
subject = subject
--Load attachment inside body
body = {
preamble = "",
[1] = {
headers = {
["content-type"] = 'application/x-7z-compressed',
["content-disposition"] = 'attachment; filename="'..src..'"',
["content-description"] = '.. src ..',
["content-transfer-encoding"] = "BASE64",
body = ltn12.source.chain(
ltn12.source.file(io.open(dst, "rb")),
ltn12.filter.chain(
mime.encode("base64"),
mime.wrap()
epilogue = epilogue
--Send the email
r, e = smtp.send(settings)
--Create alert when sending gives an error with error message
if (e) then
log (e)
log (r)
alert("Could not send email: ", e, "\n")
log("Send Mail")
--Delete created backup file from tmp folder inside HL
os.execute('cd /lib/genohm-scada/storage && rm -rf user userlib.luas blockly.luas initscript.lua helpers.js genohm-scada.config filter*')
