Logic Machine Forum
scripting - Printable Version
+--- Thread: scripting (/showthread.php?tid=5024)
Pages: 1 2
RE: scripting - Daniel - 16.10.2023
Press scan selected
RE: scripting - abby - 16.10.2023
(16.10.2023, 12:29)Daniel Wrote: Press scan selected
Go to System config - Netwotk - BAcnet Settings and de-select: Server enabled
Save and scan again
(16.10.2023, 12:38)Daniel Wrote: Go to System config - Netwotk - BAcnet Settings and de-select: Server enabled
Save and scan again
nothing showed when i can
RE: scripting - admin - 16.10.2023
Post your full script.
(16.10.2023, 12:57)admin Wrote: Post your full script.
Use 'positive integer value' instead of 'analog value'. You can't write true / false to an integer value, try using 1 and 0 instead.
(16.10.2023, 13:11)admin Wrote: Use 'positive integer value' instead of 'analog value'. You can't write true / false to an integer value, try using 1 and 0 instead.
done still not working
(16.10.2023, 13:22)Daniel Wrote: Use 'positive integer value' instead of 'analog value'.
still not working
show your script
(16.10.2023, 13:30)Daniel Wrote: show your script
Use YABE(bacnet client software on PC) and check what values this objects actually allows and if it works from yabe.
RE: scripting - abby - 17.10.2023
(16.10.2023, 14:03)Daniel Wrote: Use YABE(bacnet client software on PC) and check what values this objects actually allows and if it works from yabe.
Sorry But I thing you getting what i'm trying to say
I need Script that control Casambi Curtain from Logic Machine Beacause we are not getting proper or right script. If you can then please send me script.
RE: scripting - Erwin van der Zwart - 17.10.2023
If we don’t know how your BACnet environment looks like we cannot say anything why the script is not working, if you can do a discovery with YABE and show us how the datapoints in the BACnet device 400001 looks like then we might be able to help you further, just calling out you need a script won’t get you any further as we don’t have all the details …
