ModBus Idegis DOM-24 can´t write - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: ModBus Idegis DOM-24 can´t write (/showthread.php?tid=5130) |
ModBus Idegis DOM-24 can´t write - jpnordexpert - 04.12.2023 Hello, i have a problem with An Idegis equipment DOM-24. I can read all without problem but it is imposible to write to it. This is the mapping { "manufacturer": "Idegis", "description": "Dom-24", "mapping": [ { "name": "Alarma Caudal", "bus_datatype": "bool", "type": "discreteinput", "address": 16 }, { "name": "Alarma Baja salinidad", "bus_datatype": "bool", "type": "discreteinput", "address": 17 }, { "name": "Alarma Alta salinidad", "bus_datatype": "bool", "type": "discreteinput", "address": 18 }, { "name": "Alarma Celula de electrolisis", "bus_datatype": "bool", "type": "discreteinput", "address": 19 }, { "name": "Alarma pH bajo", "bus_datatype": "bool", "type": "discreteinput", "address": 20 }, { "name": "Alarma pH alto", "bus_datatype": "bool", "type": "discreteinput", "address": 21 }, { "name": "Alarma Sobredosis min pH", "bus_datatype": "bool", "type": "discreteinput", "address": 23 }, { "name": "Alarma Valor ORP bajo", "bus_datatype": "bool", "type": "discreteinput", "address": 24 }, { "name": "Alarma Valor ORP alto", "bus_datatype": "bool", "type": "discreteinput", "address": 25 }, { "name": "Alarma Valor Cloro bajo", "bus_datatype": "bool", "type": "discreteinput", "address": 26 }, { "name": "Alarma Valor Cloro alto", "bus_datatype": "bool", "type": "discreteinput", "address": 27 }, { "name": "Producción de Cloro", "bus_datatype": "uint16", "type": "inputregister", "address": 5, "units": "g/h" }, { "name": "Producción", "bus_datatype": "uint16", "type": "inputregister", "address": 6, "units": "%" }, { "name": "Consigna Producción", "bus_datatype": "uint16", "type": "inputregister", "address": 7, "units": "%" }, { "name": "Resulta test de sal", "bus_datatype": "uint16", "type": "inputregister", "address": 8, "units": "mV" }, { "name": "Consigna producción W", "bus_datatype": "uint16", "type": "register", "address": 38, "writeable":true, "write_multiple":true} ] } The last line is where is the problem. I don`t know what is wrong? the desciption of the Idegis only allows to write multiple coil and multiple register.
IDEGIS modbus v1.3.0 ES.pdf (Size: 408.31 KB / Downloads: 11)RE: ModBus Idegis DOM-24 can´t write - admin - 04.12.2023 Incorrect spelling: field name must be writable not writeable RE: ModBus Idegis DOM-24 can´t write - jpnordexpert - 13.12.2023 (04.12.2023, 12:54)admin Wrote: Incorrect spelling: field name must be writable not writeable Uffff, sorry...Thankyou,,but do the same...imposible to write...some idea? { "manufacturer": "Idegis", "description": "Dom-24", "mapping": [ { "name": "Alarma Caudal", "bus_datatype": "bool", "type": "discreteinput", "address": 16 }, { "name": "Alarma Baja salinidad", "bus_datatype": "bool", "type": "discreteinput", "address": 17 }, { "name": "Alarma Alta salinidad", "bus_datatype": "bool", "type": "discreteinput", "address": 18 }, { "name": "Alarma Celula de electrolisis", "bus_datatype": "bool", "type": "discreteinput", "address": 19 }, { "name": "Alarma pH bajo", "bus_datatype": "bool", "type": "discreteinput", "address": 20 }, { "name": "Alarma pH alto", "bus_datatype": "bool", "type": "discreteinput", "address": 21 }, { "name": "Alarma Sobredosis min pH", "bus_datatype": "bool", "type": "discreteinput", "address": 23 }, { "name": "Alarma Valor ORP bajo", "bus_datatype": "bool", "type": "discreteinput", "address": 24 }, { "name": "Alarma Valor ORP alto", "bus_datatype": "bool", "type": "discreteinput", "address": 25 }, { "name": "Alarma Valor Cloro bajo", "bus_datatype": "bool", "type": "discreteinput", "address": 26 }, { "name": "Alarma Valor Cloro alto", "bus_datatype": "bool", "type": "discreteinput", "address": 27 }, { "name": "Producción de Cloro", "bus_datatype": "uint16", "type": "inputregister", "address": 5, "units": "g/h" }, { "name": "Producción", "bus_datatype": "uint16", "type": "inputregister", "address": 6, "units": "%" }, { "name": "Consigna Producción", "bus_datatype": "uint16", "type": "inputregister", "address": 7, "units": "%" }, { "name": "Resulta test de sal", "bus_datatype": "uint16", "type": "inputregister", "address": 8, "units": "mV" }, { "name": "Consigna producción W", "bus_datatype": "uint16", "type": "register", "address": 38, "writable":true, "write_multiple":true} ] } RE: ModBus Idegis DOM-24 can´t write - Daniel - 13.12.2023 Did you delete device and add it again after uploading new profile? RE: ModBus Idegis DOM-24 can´t write - jpnordexpert - 13.12.2023 (13.12.2023, 13:09)Daniel Wrote: Did you delete device and add it again after uploading new profile? Yes. i do. RE: ModBus Idegis DOM-24 can´t write - Daniel - 13.12.2023 Can't really check manuals as they in Spanish, are sure write multiple is necessary? RE: ModBus Idegis DOM-24 can´t write - jpnordexpert - 18.12.2023 (13.12.2023, 13:55)Daniel Wrote: Can't really check manuals as they in Spanish, are sure write multiple is necessary? i translate the manual. In the Supported Features it is only posible to write multiple. RE: ModBus Idegis DOM-24 can´t write - Daniel - 18.12.2023 Can you read this register correctly? RE: ModBus Idegis DOM-24 can´t write - jpnordexpert - 22.01.2024 Yes the read funtion is correct RE: ModBus Idegis DOM-24 can´t write - Daniel - 22.01.2024 You didn't specify datatype, try uint16 RE: ModBus Idegis DOM-24 can´t write - jpnordexpert - 24.01.2024 Yes it was the problem, now work correctly. Thank you very much.. |
