gateway on reactor - Printable Version
+--- Thread: gateway on reactor (/showthread.php?tid=5403)
gateway on reactor - Frank68 - 02.05.2024
Greetings
even with the latest firmware if I use GSM/LTE don't I have to put gateway in the network configuration?
I have a reactor with GW that sends emails but then doesn't send me text messages.
I have other reactors that even if they have the gw send SMS, the difference depends on what, the scripts and configurations are the same.
Thank you
RE: gateway on reactor - admin - 02.05.2024
When a mobile connection is established the default gateway is replaced with the one provided via the mobile connection. But this does not affect sending SMS as it does not require mobile Internet connection.
RE: gateway on reactor - Frank68 - 02.05.2024
(02.05.2024, 12:14)admin Wrote: When a mobile connection is established the default gateway is replaced with the one provided via the mobile connection. But this does not affect sending SMS as it does not require mobile Internet connection.
So what could the failure to send SMS depend on? The SIM is loaded and active.
the GSM signal is present.
Check Error log for any errors from the SMS script. Make sure that the correct port is set, it depends on the modem model. It should be either /dev/ttyACM3 or /dev/ttyUSB2
(02.05.2024, 12:23)admin Wrote: Check Error log for any errors from the SMS script. Make sure that the correct port is set, it depends on the modem model. It should be either /dev/ttyACM3 or /dev/ttyUSB2
I have check the port is /dev/ttyACM3
What about the Error log?
(02.05.2024, 12:34)admin Wrote: What about the Error log?
nothing
RE: gateway on reactor - Frank68 - 06.05.2024
I have no error on log
RE: gateway on reactor - admin - 07.05.2024
Can you send ZeroTier access via PM?
RE: gateway on reactor - Frank68 - 07.05.2024
(07.05.2024, 07:49)admin Wrote: Can you send ZeroTier access via PM?
Yes tomorrow I return in office and I send You the access.
tank's
RE: gateway on reactor - Frank68 - 08.05.2024
tank's
I have send you PM
tank's
RE: gateway on reactor - lamgia99 - 12.02.2025
Hello, I have a problem. My SMS is sent normally, but after about half a month or a month, my SMS cannot be sent anymore until I turn off the Lm and restart it. Can you give me a solution? Thank you.
RE: gateway on reactor - admin - 12.02.2025
1. Replace AT:read() function in user.sms with the following code.
2. Restart the SMS script.
3. Post what you have in Logs when this issue happens again.
function AT:read(timeout)   local char, err, timeout, deftimeout, line   -- default timeout is 1 second, converted to 0.1 sec ticks   timeout = tonumber(timeout) or 1   timeout = timeout * 10   deftimeout = timeout   -- read until got one line or timeout occured   while timeout > 0 do     -- read 1 char     char, err = self.port:read(1, 0.1)     -- got data     if char then       -- got LF, end of line       if char == '\n' then         -- convert to string and empty buffer         line = table.concat(self.buffer)         self.buffer = {}         line = line:trim()         -- return only lines with data         if #line > 0 then           log('read line', line)           return line         -- reset timeout         else           timeout = deftimeout         end       -- ignore CR       elseif char ~= '\r' then         table.insert(self.buffer, char)       end     -- read timeout     elseif err == 'timeout' then       timeout = timeout - 1     -- other error     else       break     end   end   log('read timeout', self.buffer)   return nil, err end
RE: gateway on reactor - lamgia99 - 13.02.2025
(12.02.2025, 10:43)admin Wrote: 1. Replace AT:read() function in user.sms with the following code.
RE: gateway on reactor - admin - 13.02.2025
Make sure that you are using the latest script from here: https://kb.logicmachine.net/notifications/sms/
Post what you have in LM Alerts and System config > Status > System log.
