Greetings
even with the latest firmware if I use GSM/LTE don't I have to put gateway in the network configuration?
I have a reactor with GW that sends emails but then doesn't send me text messages.
I have other reactors that even if they have the gw send SMS, the difference depends on what, the scripts and configurations are the same.
When a mobile connection is established the default gateway is replaced with the one provided via the mobile connection. But this does not affect sending SMS as it does not require mobile Internet connection.
(02.05.2024, 12:14)admin Wrote: When a mobile connection is established the default gateway is replaced with the one provided via the mobile connection. But this does not affect sending SMS as it does not require mobile Internet connection.
So what could the failure to send SMS depend on? The SIM is loaded and active.
the GSM signal is present.
Check Error log for any errors from the SMS script. Make sure that the correct port is set, it depends on the modem model. It should be either /dev/ttyACM3 or /dev/ttyUSB2
(02.05.2024, 12:23)admin Wrote: Check Error log for any errors from the SMS script. Make sure that the correct port is set, it depends on the modem model. It should be either /dev/ttyACM3 or /dev/ttyUSB2
12.02.2025, 04:07 (This post was last modified: 12.02.2025, 04:07 by lamgia99.)
Hello, I have a problem. My SMS is sent normally, but after about half a month or a month, my SMS cannot be sent anymore until I turn off the Lm and restart it. Can you give me a solution? Thank you.
(07.05.2024, 07:49)admin Wrote: Can you send ZeroTier access via PM?
1. Replace AT:read() function in user.sms with the following code.
2. Restart the SMS script.
3. Post what you have in Logs when this issue happens again.
(12.02.2025, 10:43)admin Wrote: 1. Replace AT:read() function in user.sms with the following code.
