Modbus Connection ATV320 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Modbus Connection ATV320 (/showthread.php?tid=5806) |
Modbus Connection ATV320 - hocine - 24.12.2024 Hello all, i try to connect an ATV320 Variable speed drive from schneider electric with modbus connection. I've made many settings but it's impossible for me to connect it to the LM. In the LM, i activate the modbus RTU. i set the speed at 19200bps like the ATV In the ATV I enable the modbus i set the adress to 1 but i don't what i need to choose in this settings if some one can help me THX RE: Modbus Connection ATV320 - admin - 24.12.2024 Choose Even in Parity settings. RE: Modbus Connection ATV320 - hocine - 24.12.2024 (24.12.2024, 13:51)admin Wrote: Choose Even in Parity settings.THX Admin I made this but not connection when i made a RTU scan or a Read test RE: Modbus Connection ATV320 - admin - 24.12.2024 Try swapping RS485 A/B and make sure that GND is connected between LM and Modbus device. RE: Modbus Connection ATV320 - hocine - 24.12.2024 (24.12.2024, 14:09)admin Wrote: Try swapping RS485 A/B and make sure that GND is connected between LM and Modbus device. I switched the drive off and on again and now it works. Thanks for your help Admin |
