Issue with Astro Function in Spacelynk - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Issue with Astro Function in Spacelynk (/showthread.php?tid=5826) |
Issue with Astro Function in Spacelynk - elkim - 08.01.2025 Hi, I am experiencing an issue with the Astro function in Spacelynk, which previously worked perfectly fine for controlling outdoor lights based on sunrise and sunset times. The problem started on December 5th, and now the function behaves oddly. The lights turn on at 23:59 and turn off at 00:01, which is obviously not correct or functional. I have tested the Astro function on three different installations with various firmware versions, and all of them show the same issue. Additionally, I moved the function to its own virtual group address in Spacelynk for logging purposes, but the problem persists. All installations are located in the same city, and here are the coordinates entered into Spacelynk (the values vary slightly between the installations, but these are representative):
Has anyone else encountered a similar issue, or does anyone have suggestions for possible solutions? I would appreciate any help. Thank you in advance! Best regards, EL-KIM RE: Issue with Astro Function in Spacelynk - Daniel - 08.01.2025 We had a report of Latitude/Longitude change which most likely comes from one of SE cloud apps. Check if you have the same. RE: Issue with Astro Function in Spacelynk - elkim - 08.01.2025 (08.01.2025, 11:52)Daniel Wrote: We had a report of Latitude/Longitude change which most likely comes from one of SE cloud apps. Check if you have the same.Can you please explain further what I need to check regarding the coordinates? ☺️ RE: Issue with Astro Function in Spacelynk - Daniel - 08.01.2025 Utilities-Data and Time RE: Issue with Astro Function in Spacelynk - elkim - 08.01.2025 (08.01.2025, 13:42)Daniel Wrote: Utilities-Data and TimeThey all has the correct value according to location, and 5digits after dot. RE: Issue with Astro Function in Spacelynk - Daniel - 08.01.2025 What about timezone? RE: Issue with Astro Function in Spacelynk - elkim - 08.01.2025 (08.01.2025, 14:14)Daniel Wrote: What about timezone? That's also correct, Oslo/Europe. Im gonna try changing the coordinates on one of them to a different city down south where they actually has sun this time of year and se if that changes things. RE: Issue with Astro Function in Spacelynk - Erwin van der Zwart - 08.01.2025 Are you using the new app on this SL? RE: Issue with Astro Function in Spacelynk - elkim - 09.01.2025 (08.01.2025, 22:32)Erwin van der Zwart Wrote: Are you using the new app on this SL? Hi, I'm using the schedulers and Sunrise/Sunset functions. i tried changing the location to south of Norway and it didn't change things. RE: Issue with Astro Function in Spacelynk - Daniel - 09.01.2025 SL and LM use exactly the same logic, it must be something done by SE app. Do you use any? RE: Issue with Astro Function in Spacelynk - elkim - 09.01.2025 (09.01.2025, 09:24)Daniel Wrote: SL and LM use exactly the same logic, it must be something done by SE app. Do you use any?Customers SL does not run any apps. RE: Issue with Astro Function in Spacelynk - Daniel - 09.01.2025 Send me your backup to PM, we will try it locally. RE: Issue with Astro Function in Spacelynk - Erwin van der Zwart - 10.01.2025 If you don’t use the app, can you try disabling cloud connector or even fully remove it? I noticed same behavior and this helped, i reported it to R&D but due the holidays i have not got an answer yet.. |
