DLX1224-4CV-DALI - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: CANx (https://forum.logicmachine.net/forumdisplay.php?fid=23) +--- Thread: DLX1224-4CV-DALI (/showthread.php?tid=6085) |
DLX1224-4CV-DALI - davidchispas - 21.08.2025 Hello, I have an RGBW controller, model DLX1224-4CV-DALI, and I have detected an issue with the color control: The device assigns a separate short address for each channel (R, G, B, and W). In LM we have configured a group as RGBW to control it jointly. The group controls for on/off and intensity work correctly. However, the color control from the group has no effect. If I send the commands individually to each short address, the color change works correctly. Could this be an error? Thank you. RE: DLX1224-4CV-DALI - admin - 21.08.2025 Use this: https://kb.logicmachine.net/scripting/rgb-rgbw/ RE: DLX1224-4CV-DALI - Daniel - 21.08.2025 Look for DT8 ballasts if you want to control them via single object. |
