Can't enable RTU 3 Port | Error: RTU (serial) is not enabled - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Can't enable RTU 3 Port | Error: RTU (serial) is not enabled (/showthread.php?tid=6126) |
Can't enable RTU 3 Port | Error: RTU (serial) is not enabled - andrecosta - 24.09.2025 Hello Guys, I have an LM5p2-KC with 20240426 firmware version (LM5 Lite + Ext (i.MX6)) in witch I can't enable RTU 3 Port. I go to RTU Settings and I check the box that says "RTU 3 - RTU (serial) enabled:" but when I save that settings and I go again to RTU Settings, the box remain unchecked. I have tried several times but it's always happening the same thing. After that if I try to add a Modbus device in RTU 3 Port I get an error that says "RTU (serial) is not enabled". I'm attaching some print screens here. Can you help me with this? Thank you. RE: Can't enable RTU 3 Port | Error: RTU (serial) is not enabled - admin - 24.09.2025 See if RS485-3 is listed in System config > Status > System status > Serial ports Check this: https://forum.logicmachine.net/showthread.php?tid=5907 RE: Can't enable RTU 3 Port | Error: RTU (serial) is not enabled - andrecosta - 24.09.2025 No, it's not. But I already have used this RTU 3 Port of this specific LM in the past and with this firmware version. What can I do? RE: Can't enable RTU 3 Port | Error: RTU (serial) is not enabled - admin - 24.09.2025 Check the thread that I've linked above for a solution. RE: Can't enable RTU 3 Port | Error: RTU (serial) is not enabled - andrecosta - 24.09.2025 (24.09.2025, 11:31)admin Wrote: Check the thread that I've linked above for a solution. It worked! Thanks. |
