REACTOR response ping on Network problem - Printable Version
+--- Thread: REACTOR response ping on Network problem (/showthread.php?tid=6391)
REACTOR response ping on Network problem - Frank68 - 16.04.2026
Good morning
I have several questions. If I have a reactor with firmware version 20240426, which I use the old display, I'm having a problem with the LM not being seen by the PCs on the network, while the panels see it correctly. Can I try updating to the latest version to see if the problem persists? Will the program remain on the old display?
I received an email from Zerotier that they'll be releasing a new version. I hope the old one stays, since the new free version only has 10 devices; otherwise, it's up to 100, which will be expensive. I use 21 devices on the VPN. Do you have any news on this?
Thank you very much. Sorry if I took the opportunity to ask several questions.
RE: REACTOR response ping on Network problem - Daniel - 16.04.2026
If a display still has acces but not PC then it must be some networrk problem, talk to IT maybe something is restricted somwhere. Firmware upgrade will not change anything.
Zerotier - as I understand the account created before the limit will stay as before but it is just my assumption. A work around is to have more accounts Smile but I agree they went crazy with the new pricing.
PS. Next time structure your questions in poins Smile
RE: REACTOR response ping on Network problem - Frank68 - 16.04.2026
(16.04.2026, 09:03)Daniel Wrote: If a display still has acces but not PC then it must be some networrk problem, talk to IT maybe something is restricted somwhere. Firmware upgrade will not change anything.
It could be a LM configuration problem. The panels are reachable from the PC. The reactor is NOT is on the same VLAN.
What should I check?
Thank's
I have zero knowledge about your network setup. You can try connecting pc instead of the panel with same setup to see.
(16.04.2026, 09:33)Daniel Wrote: I have zero knowledge about your network setup. You can try connecting pc instead of the panel with same setup to see.
Is not possible is different VLAN, for security.
Thank's
