LM Cloud with several devices - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Visu (https://forum.logicmachine.net/forumdisplay.php?fid=24) +--- Thread: LM Cloud with several devices (/showthread.php?tid=6409) |
LM Cloud with several devices - jmir - 30.04.2026 Hi, We have a client who has several LMs spread across different installations. Using the new visualization and to control them from the Cloud, is there a way to see them all and choose which one to access? We did a test by putting 2 of them in the same network but when accessing the cloud (both from the web and from the LM Home app) by default it enters one of them and we do not see a way to change to the other. We also did the test by creating 2 networks and in this case a menu appears to select which network to access from the bottom of the side menu in the visualization. Is this the only way to switch between them? What is the difference between creating two networks or putting two devices in the same one? RE: LM Cloud with several devices - admin - 30.04.2026 Yes, the network selector in the menu is the only way to switch from one network to another. The main use case for connecting several LMs to a single cloud network is data exchange via cloud. In your case you need to create a separate network for each LM. RE: LM Cloud with several devices - jmir - 30.04.2026 And why does the mosaic appear if I access it through the cloud even though I don't have it installed? RE: LM Cloud with several devices - admin - 30.04.2026 The list of cloud apps is fixed and does not depend on what is installed on the linked LM. Hiding certain cloud apps automatically should be possible. This will be implemented later. |
