kWh meter, a ZIV E0090 P1 port - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: kWh meter, a ZIV E0090 P1 port (/showthread.php?tid=6411) |
kWh meter, a ZIV E0090 P1 port - cheist - 01.05.2026 I received a new kWh meter, a ZIV E0090. I think it’s DSMR 5.0. I’m currently using this script, which works, but can it be extended with real-time current values and such? I’d actually like to use everything that can be read out in graphs. -- P1 poort uitlezen (ultra-licht) local LAST = '!' local serial = require('serial') local port = serial.open('/dev/ttyUSB0', { baudrate = 115200, -- DSMR2/3: 9600, DSMR4: 115200 databits = 8, -- DSMR2/3: 7, DSMR4: 8 stopbits = 1, parity = 'none',-- DSMR4: 'none' duplex = 'full' }) local function read_frame(p) local buf = {} while true do local c = p:read(1) if c == nil or c == LAST then break elseif c ~= '\r' then buf[#buf+1] = c end end return table.concat(buf) end local data = read_frame(port) port:flush() if not data then return end -- Helper: parse getal met punt, return number of nil local function num(pat) local s = data:match(pat) return s and tonumber(s) or nil end -- Verbruik kWh (T1,T2) en totaal local t1 = num([[1%-0:1%.8%.1%((%d+%.%d+)]]) local t2 = num([[1%-0:1%.8%.2%((%d+%.%d+)]]) if t1 then grp.update('14/0/1', t1) end if t2 then grp.update('14/0/2', t2) end local v_tot = (t1 or 0) + (t2 or 0) if t1 or t2 then grp.update('14/0/0', v_tot) end -- Verbruik € (alleen als prijs aanwezig) do local prijs = grp.getvalue('14/0/11') if type(prijs) == 'number' and (t1 or t2) then grp.update('14/0/13', v_tot * prijs) end end -- Retour kWh (T1,T2) en totaal local r1 = num([[1%-0:2%.8%.1%((%d+%.%d+)]]) local r2 = num([[1%-0:2%.8%.2%((%d+%.%d+)]]) if r1 then grp.update('14/0/4', r1) end if r2 then grp.update('14/0/5', r2) end local r_tot = (r1 or 0) + (r2 or 0) if r1 or r2 then grp.update('14/0/3', r_tot) end -- Retour € (alleen als prijs aanwezig) do local prijs = grp.getvalue('14/0/12') if type(prijs) == 'number' and (r1 or r2) then grp.update('14/0/14', r_tot * prijs) end end -- Actueel tarief (T1/T2 laatste cijfer) do local t = data:match([[0%-0:96%.14%.0%(%d%d%d(%d)]]) if t then grp.update('14/0/10', t) end end -- Actueel verbruik kW/W en € do local p_kw = num([[1%-0:1%.7%.0%((%d+%.%d+)]]) if p_kw then grp.update('14/0/6', p_kw) grp.update('14/0/7', p_kw * 1000) local prijs = grp.getvalue('14/0/11') if type(prijs) == 'number' then grp.update('14/0/15', p_kw * prijs) end end end -- Actueel retour kW/W do local pr_kw = num([[1%-0:2%.7%.0%((%d+%.%d+)]]) if pr_kw then grp.update('14/0/8', pr_kw) grp.update('14/0/9', pr_kw * 1000) end end -- Gas m³ en € do local gas = num([[0%-1:24%.2%.1%(.+%)%((%d+%.%d+)]]) if gas then grp.update('14/1/0', gas) local prijs = grp.getvalue('14/1/1') if type(prijs) == 'number' then grp.update('14/1/2', gas * prijs) end end end |
