[OLD] LogicMachine firmware 2017.05 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: Announcements (https://forum.logicmachine.net/forumdisplay.php?fid=7) +--- Forum: Software updates (https://forum.logicmachine.net/forumdisplay.php?fid=13) +--- Thread: [OLD] LogicMachine firmware 2017.05 (/showthread.php?tid=806) |
[OLD] LogicMachine firmware 2017.05 - admin - 24.05.2017 RC2 is ready for testing, this is mostly a bug-fix releases with minor changes: 1. Allow empty string for object custom values, it was previously ignored 2. Fix custom value display when status object is used 3. Scripting: fix category filter not working 4. Set object comment/description when importing JSON converted from .knxproj (http://openrb.com/knxproj/) 5. ModBus: allow JSON profiles with UTF-8 BOM mark 6. ModBus: show JSON error when profile cannot be parsed 7. Apps home page: only load style.css for widgets, not all apps (older version of WireGeo app broke home page layout) 8. Add SHA256 hash function to Lua encdec library 9. MBUS: add duplex option for MBUS-RS485 gateways LM2 IMX: https://dl.openrb.com/lm-17/lm2i-20170519.img LM3 V1 (4 x RS-485): https://dl.openrb.com/lm-17/lm3v1-20170519.img LM3 V2 (3 x RS-485 and 1 x RS-232): https://dl.openrb.com/lm-17/lm3v2-20170519.img LM4: https://dl.openrb.com/lm-17/lm4-20170519.img LM5 lite: https://dl.openrb.com/lm-17/lm5m3-20170519.img LM5 lite with extensions: https://dl.openrb.com/lm-17/lm5m3ex-20170519.img LM5 4 DIN units: https://dl.openrb.com/lm-17/lm5m4-20170519.img LM Ambient: https://dl.openrb.com/lm-17/lmwall-20170519.img LM Reactor Lite: https://dl.openrb.com/lm-17/rctl-20170519.img LM Reactor V1: https://dl.openrb.com/lm-17/reactor-20170519.img LM Reactor V2: https://dl.openrb.com/lm-17/reactorv2-20170519.img LM Reactor V3: https://dl.openrb.com/lm-17/reactorv3-20170519.img Extra packages: https://dl.openrb.com/lm-17/pkg LM5 Power devices Note: if upgrade does not work, run this script once: https://gist.github.com/jsopenrb/4ba040d83cd25d51bf70a0dbc6b74447 LM5 lite: https://dl.openrb.com/lm-17-imx6/lm5m3-20170519.img LM5 lite with extensions: https://dl.openrb.com/lm-17-imx6/lm5m3ex-20170519.img LM5 4 DIN units: https://dl.openrb.com/lm-17-imx6/lm5m4-20170519.img Extra packages: https://dl.openrb.com/lm-17-imx6/pkg Warning Due to Apps server upgrade some Apps cannot be installed if running 2017 RC1 or RC2 firmware. To fix this, please install LMUP patch through Utilities -> Install updates. Standard LM devices: https://dl.openrb.com/lmup/2017.05.29-apps-install.lmup LM2 and Load Balancer files coming later RE: [PRE-RELEASE] LogicMachine firmware 2017.05 - Jørn - 28.05.2017 I've got certain on/off switches in touch visu, when random toggling these causes the LM to reboot. Not script related as there are no scripts started by on/off or status object of this. Had the same issue in RC1, have not noticed this in previous releases. Any ideas? RE: [PRE-RELEASE] LogicMachine firmware 2017.05 - admin - 29.05.2017 Which hardware are you using? Can you provide remote access to your device or a backup of your project if remote access is not possible? RE: [PRE-RELEASE] LogicMachine firmware 2017.05 - Jørn - 29.05.2017 I'll send you a PM. RE: [PRE-RELEASE] LogicMachine firmware 2017.05 - buuuudzik - 01.06.2017 Maybe today is a good day for releasing the RC2 firmware for Load Balancer? RE: [PRE-RELEASE] LogicMachine firmware 2017.05 - admin - 01.06.2017 RC3 for Load Balancer: https://dl.openrb.com/lm-17/lb-20170601.img Other images and changelog coming later today. |
