touch button without status - Printable Version
+--- Thread: touch button without status (/showthread.php?tid=845)
touch button without status - Matt - 18.06.2017
Is there a way to create a Icon only button in touch mode ?
For example to start a scene, or to stop a shutter.
Thanks,
Matt
RE: touch button without status - Erwin van der Zwart - 18.06.2017
In the visu editor, use send fixed value on the element and send the scene value or a 0 or 1
RE: touch button without status - Matt - 19.06.2017
(18.06.2017, 20:41)Erwin van der Zwart Wrote: Hi,
Hi Erwin,
Yes, that's what I do already, but on the touch display the value and checkbox is still visible.
I did select "Icon" only but it's only changing the usermode.
Thanks,
Matthieu
RE: touch button without status - Erwin van der Zwart - 19.06.2017
The checkbox cannot be removed as it is your active element, the value can be removed with custom css.
RE: touch button without status - Auzzii - 12.07.2017
Hi.
Is it possible to change button icon?
tnx
RE: touch button without status - AEK - 12.07.2017
(12.07.2017, 09:58)Auzzii Wrote: Hi.
tnx
yes it's possible via base64 coded icon.
that's example for changing slider position icon
.slider-handle{ padding: 0px 0px !important; width:            61px !important; height:           61px !important; background-image: url("data:image/png;base64,iVBORw0K… (icone code)"); background-color: transparent !important; border: 0px; box-shadow: none !important; }
on this site you can convert png icon to base64 code
https://www.base64-image.de/
that's result of code above:
[Image: 7.jpg]
