touch button without status
Is there a way to create a Icon only button in touch mode ?
For example to start a scene, or to stop a shutter.
Thanks,
Matt
In the visu editor, use send fixed value on the element and send the scene value or a 0 or 1
(18.06.2017, 20:41)Erwin van der Zwart Wrote: Hi,
Hi Erwin,
Yes, that's what I do already, but on the touch display the value and checkbox is still visible.
I did select "Icon" only but it's only changing the usermode.
Thanks,
Matthieu
The checkbox cannot be removed as it is your active element, the value can be removed with custom css.
Hi.
Is it possible to change button icon?
tnx
(12.07.2017, 09:58)Auzzii Wrote: Hi.
tnx
yes it's possible via base64 coded icon.
that's example for changing slider position icon
.slider-handle{ padding: 0px 0px !important; width:            61px !important; height:           61px !important; background-image: url("data:image/png;base64,iVBORw0K… (icone code)"); background-color: transparent !important; border: 0px; box-shadow: none !important; }
on this site you can convert png icon to base64 code
https://www.base64-image.de/
that's result of code above:
[Image: 7.jpg]
