Unused Processes
In a typical installation,  I won't be using the Dali, 1-wire, bacnet and modbus parts of the LM.  Is there a way to remove \ disable these components and make this permanent?   The reason I ask because I saw with the Processes app that these modules were using a combined CPU usage of 10%.  Surely  the LM would be more efficient if we could eliminate this overhead.
Thanks,
Roger
You can uninstall genohm-scada-dali and similar packages from System config > System > Packages. Keep in mind that firmware upgrade will revert them back.
(16.04.2018, 06:30)admin Wrote: You can uninstall genohm-scada-dali and similar packages from System config > System > Packages. Keep in mind that firmware upgrade will revert them back.
Thank you,  works good.
