17.11.2019, 16:47
I am working on automatic generation of widgets in the normal visu. So far I have been able to generate the widgets based on a room list and the objects in the object list. It is working rather nicely, but I have one problem.
As I am putting a lot of objects on the widget I have made a table in the script that contains the different parameters for the objects based on the function conde we use in every project. The table look like this for HVAC objects (not yet complete, more codes will be added later):
The problem I am having is that the objects are added to the widget in alphabetical order based on the value in 'kode'. I have tried to change this by adding the column 'order', but that did not help.
The first value I use from the table when adding objects are the 'kode' that is used to find the group address from the object list.
I thought that the objects would be added in the order I put them in the table as I am using ipairs ro run thought the table and add objects.
Anyone has an idea how I can decide the order?
HVACadresses = {
{order = 'A', kode = 'ACTUAL_TEMP', statusadr = 'ACTUAL_TEMP', tekst = 'Temperatur', format = ROverdi, klasse = 'right-align', readonly = 1},
{order = 'B', kode = 'DAY_H_SETPOINT', statusadr = 'DAY_H_SETPOINT', tekst = 'Varmesetpunkt dag', format = RWverdi, klasse = 'right-align', readonly = 0},
{order = 'C', kode = 'DAY_C_SETPOINT', statusadr = 'DAY_C_SETPOINT', tekst = 'Kjølesetpunkt dag', format = RWverdi, klasse = 'right-align', readonly = 0},
{order = 'd', kode = 'NIGHT_H_SETPOINT', statusadr = 'NIGHT_H_SETPOINT', tekst = 'Varmesetpunkt natt', format = RWverdi, klasse = 'right-align', readonly = 0},
{order = 'e', kode = 'NIGHT_C_SETPOINT', statusadr = 'NIGHT_C_SETPOINT', tekst = 'Kjølesetpunkt natt', format = RWverdi, klasse = 'right-align', readonly = 0},
{order = 'f', kode = 'ACTUAL_SETPOINT', statusadr = 'ACTUAL_SETPOINT', tekst = 'Faktisk setpunkt', format = ROverdi, klasse = 'right-align', readonly = 1},
{order = 'g', kode = 'SET_H_OUTP', statusadr = 'SET_H_OUTP', tekst = 'Varmepådrag', format = ROverdi, klasse = 'right-align', readonly = 1},
{order = 'h', kode = 'SET_H1_OUTP', statusadr = 'SET_H1_OUTP', tekst = 'Varmepådrag 1', format = ROverdi, klasse = 'right-align', readonly = 1},
{order = 'i', kode = 'SET_H2_OUTP', statusadr = 'SET_H2_OUTP', tekst = 'Varmepådrag 2', format = ROverdi, klasse = 'right-align', readonly = 1},
{order = 'j', kode = 'SET_C_OUTP', statusadr = 'SET_C_OUTP', tekst = 'Kjølepådrag', format = ROverdi, klasse = 'right-align', readonly = 1},
{order = 'k', kode = 'SET_C1_OUTP', statusadr = 'SET_C1_OUTP', tekst = 'Kjølepådrag 1', format = ROverdi, klasse = 'right-align', readonly = 1},
{order = 'l', kode = 'SET_C2_OUTP', statusadr = 'SET_C2_OUTP', tekst = 'Kjølepådrag 2', format = ROverdi, klasse = 'right-align', readonly = 1},
{order = 'm', kode = 'ACTUAL_CO2', statusadr = 'ACTUAL_CO2', tekst = 'CO2', format = ROverdi, klasse = 'right-align', readonly = 1},
{order = 'n', kode = 'SETP_CO2', statusadr = 'SETP_CO2', tekst = 'Setpunkt CO2', format = RWverdi, klasse = 'right-align', readonly = 0},
{order = 'o', kode = 'SET_CO2_OUTP', statusadr = 'SET_CO2_OUTP', tekst = 'Ventilasjonspådrag', format = ROverdi, klasse = 'right-align', readonly = 1},
{order = 'p', kode = 'SET_V_OUTP', statusadr = 'SET_V_OUTP', tekst = 'Faktisk pådrag til spjeld', format = ROverdi, klasse = 'right-align', readonly = 1},
There are 10 kinds of people in the world; those who can read binary and those who don't
