Monitoring Ness/ELK Alarm Zone Status
We run a Ness (aka ELK) DX16X alarm here which as an IP connection.  The status reporting and control protocol is documented at the following link
http://www.nesscorporation.com/Software/...otocol.pdf
I can find integrations using this protocol for other platforms such as the following https://nessclient.readthedocs.io/en/lat...mples.html  and https://community.home-assistant.io/t/ne.../23285/163 but nothing for LogicMachine as yet.
I've started writing a script to connect the the system and can receive data ok, but need some help with getting the specific info and processing the responses in LUA.
socket = require("socket").tcp()   socket:connect('192.168.1.150', 2401)   socket:send(command .. '\n')   res = socket:receive('*l')   log('\nNESSCommand: ' .. command .. '\nNESSResponse : ' .. res)
Initially I'm interested in mapping the state of each zone back to objects in Logic Machine (after sending a status update command) from a resident script but haven't been able to figure out the protocol as yet.
Does anyone have a script that can do this?   Initially the is the info that I'm keen to track
0/210/1  Sealed/Unsealed state of Zone 1
0/210/2  Sealed/Unsealed state of Zone 2
0/210/3  Sealed/Unsealed state of Zone 3
0/210/4  Sealed/Unsealed state of Zone 4
0/210/5  Sealed/Unsealed state of Zone 5
0/210/6  Sealed/Unsealed state of Zone 6
0/210/7  Sealed/Unsealed state of Zone 7
0/210/8  Sealed/Unsealed state of Zone 8
0/210/9  Sealed/Unsealed state of Zone 9
0/210/10  Sealed/Unsealed state of Zone 10
0/210/11  Sealed/Unsealed state of Zone 11
0/210/12  Sealed/Unsealed state of Zone 12
0/210/13  Sealed/Unsealed state of Zone 13
0/210/14  Sealed/Unsealed state of Zone 14
0/210/15  Sealed/Unsealed state of Zone 15
0/210/16  Sealed/Unsealed state of Zone 26
and also the overall state of the alarm
0/210/20  All Zones Ok - true/false
0/210/30  Armed State - Disarmed (0), Fully armed (1), Partially armed (2)
0/210/40  Alarm Sounding - true/false
Many thanks in advance
Kind Regards
James
The protocol is rather simple, here's a starter example that you can use to decode data further:
res = socket:receive('*l') if res then   data = lmcore.hextostr(res, true)   st, addr, len, cmd, event, id, area = data:byte(1, 7)   log(st, addr, len, cmd, event, id, area) end
Note that the logged event number will be in decimal whereas it is written in hexadecimal in the protocol description.
Many thanks for the starter example. I'm still struggling a bit.
Here's an example of the data I'm receiving with the above after connecting to the alarm panel
* arg: 1
* number: 135
* arg: 2
* number: 0
* arg: 3
* number: 131
* arg: 4
* number: 97
* arg: 5
* number: 1
* arg: 6
* number: 7
* arg: 7
* number: 0
Am I correct in my interpretation that this would map to a sensor in zone / 1D 7 being triggered (event id = 1)?
Also how would I formulate an input command to retrieve the status of all 16 zones to update the group addresses in LM?
Kind Regards
James
