Import font failed
I'm trying to import font which was already imported on other LM with older firmware on the LM5 with current firmware and I have response that "Unable to get font info from file".
I am trying to recover especially tahoma_regular.ttf but also I tried others with same result.
I am attaching font which I am trying to use (with changed extension from .ttf to .txt so I can attach it).
.txt   tahoma_regular.txt (Size: 113.79 KB / Downloads: 8)
Done is better than perfect
I tried different ttf and it works fine, it must be something wrong with this file.
The file is corrupted. Tahoma is a part of default Windows fonts, you can copy it from any Windows PC.
