07.04.2021, 08:53
I want to add simple Textbox (inputbox) Like as Html Textbox component..
Is it posible do it with visulation or should i use Scripting ?
Add simple Textbox for send value.
07.04.2021, 08:53
07.04.2021, 13:45
(07.04.2021, 11:23)Daniel. Wrote: Why don't you just use Text Label? i want use text box like this for sent to a value maybe integer for dim value or Send a start time like as "08:50" or send Some Text .. and i need textbox style like this Why Not use text Label Because There isnt main object for write KNX address in Text Label properties
07.04.2021, 13:56
Well if you want to display text from an object then just use Display mode: value.
Ctrl+F5 |
