Sync error with remote cloud
Hi everybody,
I have a problem when I try to sync with the server (new remote cloud) with the old all works fine.
In the attached file you can see the capture.
Anyway the error is code 135.
Best regards Cristian
Did you try recently? We were doing some changes.
(05.05.2021, 15:33)Daniel. Wrote: Did you try recently? We were doing some changes.
I made 5 minutes ago
There will be new app update
Install this and try again
https://dl.openrb.com/pkg/lmcloud-20210503.ipk
(05.05.2021, 15:36)Daniel. Wrote: There will be new app update
Next days when I'll came back I will try again and I let you know.
Ok, with update it works. Thanks
May I ask you if the new remote cloud has some issues on Ios app for mobile?
I do have the same error here
Are you running the latest firmware and LM Cloud app? Post logs from the LM Cloud app.
(27.11.2024, 08:49)admin Wrote: Are you running the latest firmware and LM Cloud app? Post logs from the LM Cloud app.
Version: 20241003
If you have single LM - go to https://remote.logicmachine.net/settings, click Actions > Create new connection string then set this connection string in the LM Cloud app.
If you have multiple LMs connecting to the same network then any additional LM must be authorized in Actions > Authorize additional LM by ID. LM ID is shown in the bottom left corner of the LM Cloud app.
I do have 3 LM on the same network, two of them have their own cloud network and they work fine.
this is the 3rd one
It's possible to connect multiple LMs to the same cloud network but only the first is authorized automatically, additional LMs must be authorized manually.
If you want to use separate cloud networks per each LM then either reset the connection string or create a new network for LM that cannot connect.
Recreate the cloud network; it fixed the problem. Thanks.
I was facing same issue and for me it was good moment to switch to other emailaddress.
However when registering a new email address I get no further then the Privacy Policy Terms.
Getting a empty browser with:
Please support :-)
Try again now, it should be working.
Yes!! Thx works again.
