Mosaic: RGBW dimmer
is there a reason why in the object "RGBW dimmer" there is no the "White status value feedback object"?
Because white is calculated from red,green, blue values so the feedback would be ignored anyway.
(27.09.2021, 08:16)Daniel Wrote: Because white is calculated from red,green, blue values so the feedback would be ignored anyway.
Hi Daniel, I am not totally agree with you.
There are Knx devices which manage spotlight and strip led RGBW. The White in that case Is not made of RGB but there is the forth Channel for white light only.
It this case the feedback object for White It Is necessary.
