Generic TCP Server for external requests
I am not a big fan of the example : http://openrb.com/example-lm2-as-tcp-ser...-requests/
It uses the following principle :
- the resident script is the TCP server :
  - manages TCP clients
  - listen on UDP for internal LM requests
- the resident script do receive client request and process them
- other LM scripts/events use UDP to communicate to the TCP server and transmit data to be sent
For me, there is some limitations :
- only 5 messages per second are read by TCP server on the UDP side
- data can be lost with UDP
As I need to send a lot of data, I did use the internal storage instead of UDP.
I am sharing this as a generic TCP server that can be customized for every need.
So the idea is the following :
  - manage TCP clients
  - read the internal storage for internal LM requests
- other LM scripts/events use internal storage to communicate to the TCP server and transmit data to be sent
First, the User Library :
-- TCP Server user library --general debug tcp_debug = false --networking debug tcp_debug_tcp = false -- additionnal debug tcp_debug_verbose = false --store a message to be send into the queue function tcp_queue(message)  if (tcp_debug_verbose) then    alert("tcp_queue : "..message)  end  local tcp_Q = storage.get('tcpQ')  table.insert(tcp_Q,message)     storage.set('tcpQ', tcp_Q) end
Now the resident script with sleep interval 0 :
require('copas') --[[ Resident script for TCP server Manage client connexions Receive requests from clients Also send events through tcpQ storage debug variables are set in the user library ]]-- --communication port to listen on local tcp_port = 6789 if (tcp_debug) then  alert ("TCP Server start") end -- send a message to the peers function tcp_sendmessage(message)  if (tcp_debug_tcp) then    alert ("tcp_sendmessage : ".. message)     end  for id, sock in pairs(tcp_clients) do    sock:send(message .. '\r\n')  end end     -- incoming data handler, manage each message sent by clients to LM function tcp_datahandler(sock, data)  local ip, port  ip, port = sock:getpeername()      if tcp_debug_tcp then    alert('tcp_datahandler receive data from %s:%d - %s', ip, port, data)  end -- add your code to process data end -- connection handler, manage new peers function tcp_connhandler(sock)  -- enable keep-alive to check for disconnect events  sock:setoption('keepalive', true)  local ip, port, data, err, id  -- get ip and port from socket  ip, port = sock:getpeername()  -- client id  id = string.format('%s:%d', ip, port)  alert('tcp_connhandler connection from %s', id)  -- save socket reference  tcp_clients[ id ] = sock  -- main reader loop  while true do    -- wait for single line of data (until \n, \r is ignored)    data, err = copas.receive(sock, '*l')    -- error while receiving    if err then      alert('tcp_connhandler closed connection from %s:%d', ip, port)      -- remove socket reference      tcp_clients[ id ] = nil      return    end    -- handle data frame    tcp_datahandler(sock, data)  end end -- init server handler if not tcp_ready then    if (tcp_debug) then    alert ("TCP Server init start")  end     -- list of client sockets  tcp_clients = {}  --variable for the queue  tcp_Q = {}  --empty the storage queue  storage.set('tcpQ', tcp_Q)  -- bind to port  tcp_tcpserver = socket.bind('*', tcp_port)  -- error while binding, try again later  if not tcp_tcpserver then    os.sleep(5)    error('tcp server realization init error: cannot bind')  end  -- set server connection handler  copas.addserver(tcp_tcpserver, tcp_connhandler)  tcp_ready = true    if (tcp_debug) then    alert ("TCP Server init end")     end end -- loop to manage packets while true do  --retreive the queue  tcp_Q = storage.get('tcpQ')  storage.set('tcpQ', {})  --sending the queue  for index, value in ipairs(tcp_Q) do    if tcp_debug then         alert("TCP Server sending item "..tostring(index).." : "..tostring(value))    end    tcp_sendmessage(value)  end  --wait for tcp request during 0.1s  copas.step(0.1) end if (tcp_debug) then  alert ("TCP Server closed") end
Event base script :
value = knxdatatype.decode(event.datahex, dt.bool) tcp_queue('Lamp is' .. (value and 'ON' or 'OFF'))
Matthieu
Our example can be tuned for more messages per second if needed, but it will increase CPU load slightly.
It's true that UDP packets can be lost over a network. In our example UDP communication happens locally over a virtual loopback interface, so it should be fine.
You example has a race conditions between storage.get and storage.set calls which can lead to some messages being lost.
Anyway, if you really need to process a large amount of data you should use some ready-made solutions like MQTT.
Thanks for the feedback, in my case (used with RTI, my user interface) the risk to send 10 to 20 message at the exact same time.
How will the UDP socket react if 10 packets come in one iteration ?
So far this method works fine.
If we could call a function of a residential script from an event script it would be perfect but I didn't find another way to do it.
Basically, it's more a service/daemon than a script.
You can find an example of group monitoring script here:
http://forum.logicmachine.net/showthread.php?tid=31
Sockets are buffered on OS level so queue must get really big in order for packets to get dropped.
I am testing UDP again to compare.
Matthieu
I had issues with 10+ UDP requests per second with the following code :
while true do  message = udpserver:receive()  -- got message from udp, send to all active clients  if message then    for id, sock in pairs(clients) do      sock:send(message .. '\r\n')    end  end  copas.step(0.1) end
With this code, it's working better :
while true do  message = udpserver:receive()  while message do  -- got message from udp, send to all active clients    for id, sock in pairs(clients) do      sock:send(message .. '\r\n')    end    message = udpserver:receive()  end  copas.step(0.1) end
It does process the UDP queue at each iteration instead of one by one.
What do you think about it ?
Matthieu
You can try setting UDP socket timeout to 0, so that receive function returns either new message at once or nil + "timeout" notification. This should speed things up for you.
