Adding Tag to multiple objects
I'm pretty new to LogicMachine and I got one simple issue I'm trying to fix.
My goal here is to add a tag to a lot of objects. To be more precise, I would like to add the tag 'ENSLG_LOGS_CLIENT' to all the objects wich address start with '1/*/*'
So far I have found this script :
ListeObjets={} ---Liste contenant les strings des adresses des objets (ex: {'1/1/1','1/1/2'})
ListeTags={}  ---Liste de strings contenant les tags (ex: {'ENSLG_MA', 'PMA0'}, {'PMA0'})
for i, obj in ipairs(ListeObjets) do
  grp.addtags(obj,ListeTags)
script.disable('Ajouter tags à des objets')
This script adds all the tags in 'ListeTags' to the objects which addresses are referred in 'ListeObjets'
I would like to be able to apply the tags to all the objects with their addresses starting with '1/*/*' rather than typing each addresses myself in 'ListObjets'
I thought of using a for loop to increment the adresses, but as I've just started using LogicMachine I'm not confortable with the scripting and I could really use a hand.
Thanks for reading me !
Matthieu Papillon
You don't need script for that. Just filter your object and use Mass edit then Object properties. Select TAG and you are done
This is a very interesting tool, thanks for pointing it out.
There is one remaining issue though. Using this method deletes the tags that where already in place. I want the tags that where already here to remain, for that I believe I do have to make a script for it.
Use this script:
tags = { 'Tag1', 'Tag2', 'Tag3' } from = buslib.encodega('1/0/0') to = buslib.encodega('2/0/0') - 1 for addr = from, to do   grp.addtags(addr, tags) end
It works like a charm ! Thanks a lot for your support and reactivity, I really do appreciate it Smile
