Modbus integration
I have manage to read temperature values in LM, but I am struggling with these on my uploade image.
Not sure how to write these in my .json file.
I added my profile.
.json   Varmeanlegg.json (Size: 1.38 KB / Downloads: 24)
Did you try adding "writable": 1 to your profile?
Also check the maximum temperature register address. It should be 38 not 36.
(21.12.2021, 09:41)admin Wrote: Also check the maximum temperature register address. It should be 38 not 36.
Where do I check that?
But how can I add this in my profile:
Maximum temperature:
For Hot water demand add this to the mapping array:
{   "name": "Hot water demand",   "bus_datatype": "uint8",   "datatype": "uint16",   "type": "register",   "address": 56,   "writable": true }
(22.12.2021, 07:50)admin Wrote: Maximum temperature:
Hi, thank you for that.
How does I map this function. I've tried this:
{ "bus_address": "12/0/7", "name": "Kjøremodus", "bus_datatype": "7", "datatype": "u8", "type": "register", "address": 237 },
Butr this gives me value 1 all the time. Should get 0 for Auto, 1 for Manual and 2 for Ad.heat.
Try with "dataype":"uint16" as "u8" is not a valid datatype. See https://openrb.com/docs/modbus.htm
