Push telegram not working on every object
Hi, I am trying to get push notifications with Telegram and for some objects it is working just fine.
But now I get this error on one specific object.
This script work just fine with another object.
What could be the problem?
event.getvalue() returns Boolean for 1 bit object, not a number. So your comparison does not work and message is empty (nil). Use this instead:
value = event.getvalue() if value then   message = 'something is on' else   message = 'something is off' end
That was it.. Thank you for the quick reply!
