Stucturing data
Good evening. I'm reading the following data from an api. The timestamp is in UTC, and the table is not JSON.
Any ideas on how to make a table with the timestamp in localtime and date, and the data structured nicely?
   ["Value"]     * string: [   {     "time": 1666717200,     "price": 177.38   },   {     "time": 1666720800,     "price": 148.27   },   {     "time": 1666724400,     "price": 126.38   },   {     "time": 1666728000,     "price": 116.92   },   {     "time": 1666731600,     "price": 111.92   },   {     "time": 1666735200,     "price": 94.77   },
os.date() takes a timestamp as a second argument. This is what the API provides in "time" value.
(31.10.2022, 14:36)admin Wrote: os.date() takes a timestamp as a second argument. This is what the API provides in "time" value.
Thank you, but what about the data, what is the best way to set this up as a table?
This can be helpful: https://forum.logicmachine.net/showthread.php?tid=3391
Put data into storage and use .lp to display it.
(31.10.2022, 14:56)admin Wrote: This can be helpful: https://forum.logicmachine.net/showthread.php?tid=3391
I think maybe I did not make my self understood correctly, sorry for that.
I would like to put this data in an LUA table sorted based on time. I cant seem to figure out how to take the json data and put in a lua table. Is that possible?
The Value part looks like a JSON string. Have you tried decoding it?
(01.11.2022, 08:48)admin Wrote: The Value part looks like a JSON string. Have you tried decoding it?
got it. thanx
table.sort(spot, function(a, b)   return a.price < b.price end) min = spot[1] minvalue = min.price minhour = min.time --:match('T(%d+)') log(minvalue, minhour) max = spot[#spot] maxvalue = max.price maxhour = max.time --:match('T(%d+)') log(maxvalue, maxhour)
using this as I found on the forum and altered. How would you change so that "time" shows ad Date and Time?
This will add a "datetime" key to each table element. You can change the format string as needed. See this for possible formats: https://man7.org/linux/man-pages/man3/strftime.3.html
for _, entry in ipairs(spot) do   entry.datetime = os.date('%c', entry.time) end
thank you. and what would be the bast way to average these price values?
sum = 0 for _, entry in ipairs(spot) do   entry.datetime = os.date('%c', entry.time)   sum = sum + entry.price end avg = sum / #spot log(avg)
