Glamox / Adax Cloud
Hello. I've written this code to access cloud token and read content from cloud, and also to write target value to the heater.
Feel free to use it, and post any updates in this thread. Also thanks to ADMIN for help with this.
--Authentication script for Adax and Glamox heaters -- --Put this script as scheduled require('json') require('ssl.https') require('socket.http') require('ltn12') -- Set credentials for Adax API clientID ='xxxxxxx' --- You find this ID in your app. clientSecret ='xxxxxxx'    -- Activate this in the app, under third party integration function GetToken()   request_token_url = 'https://api-1.adax.no/client-api/auth/token'   local response_body = {}   local request_body = 'grant_type=password&username=' .. clientID .. '&password=' .. clientSecret   local body, code, hdrs, stat = socket.http.request{     url = request_token_url;     method = "POST";     headers =     {      ["Content-Type"] = "application/x-www-form-urlencoded";      ["Content-Length"] = #request_body;     };     source = ltn12.source.string(request_body);     sink = ltn12.sink.table(response_body);   }   log(code)   if code == 200 then     ret = table.concat(response_body)     ret = json.pdecode(ret)     return ret.access_token   else     log('request failed', body, code, hdrs, stat)   end end Token = GetToken() storage.set('AdaxToken', Token) --Writes token to storage for use in other scripts
--Script for reading contant from API. You get Homes, Rooms and Devices. You can read the actual temperature and current target value among other things. -- Load modules require('json') require('ssl.https') require('socket.http') require('ltn12') -- Get token from storage Token = storage.get('GlamoxToken') function RequestFromAdax(request)   request_url = 'https://api-1.adax.no/client-api' .. request   local response_body = {}   local request_body = ""   local body, code, hdrs, stat = socket.http.request{     url = request_url;     method = "GET";     headers =     {       ["Content-Type"] = "application/json";       ["Content-Length"] = #request_body;       ["Authorization"] = "Bearer " .. Token;     };     source = ltn12.source.string(request_body);     sink = ltn12.sink.table(response_body);   }      if code == 200 then     ret = table.concat(response_body)     ret = json.pdecode(ret)     return ret   else     log('request failed', body, code, hdrs, stat)   end end getContent = RequestFromAdax('/rest/v1/content/')
--Example for writing new target value to a room. You get roomID from /content/, use this to write to correct room. Script returns a status table. --Adax/Glamox -- require('json') require('ssl.https') require('socket.http') require('ltn12') --Get token from storage Token = storage.get('GlamoxToken') function WriteToAdax(request, request_body)   request_url = 'https://api-1.adax.no/client-api' .. request   local response_body = {}   local content_length   if type(request_body) == "string" then     content_length = #request_body   else     request_body = ""   end     local body, code, hdrs, stat = ssl.https.request{     url = request_url;     method = "POST";     headers =     {      ["Content-Type"] = "application/json";      ["Authorization"] = "Bearer " .. Token;      ["Content-Length"] = #request_body;     };     source = ltn12.source.string(request_body);     sink = ltn12.sink.table(response_body);   }   --log(code)       if code == 200 then     ret = table.concat(response_body)     ret = json.pdecode(ret)     return ret   else      log('request failed', body, code, hdrs, stat)   end end room_id = 123456 temperature = 25 body = json.encode({     rooms = {     { id = room_id, targetTemperature = (tostring(temperature))*100 }   } }) data = WriteToAdax('/rest/v1/control/', body)
The API is documented here: https://adax.no/wi-fi/api-development/
It does not have all the functions as the app does, because Adax did not want to much trafic on their servers. There will be a more functional update on the local API some months from now they say.
I have not made a script for local access, maybe someone will complete this task and post here?
