Hi.
I have Wiser with Schneider Powertags and measure the consumption for some of the main consumers.
JACUZZI
My jacuzzi has a dedicated power tag and I use trends to log and see the data hour by hour. In trends; when choosing month it will use the daily consumption as average consumption per day and not the exact SUM of the actual power usage for that exact day. I have tried to play around in trends to find a way to sum up the consumption per day so i can see the daily/monthly/yearly consumption easily in a table or in a visualized trend.
I guess I am doing somtehing wrong in trends as I were unable to find the soltution I was looking for. Any step by step advise of how I can use trends to achieve what I am looking for?
PowerTags built in counter.
The power tags have a built in counter accumulating the used power. I use it to show todays accumulated consumption before it is reset by a script at midnight every day.
The numbers are quite precise and a good source of data for recording the daily consumption too.
As there is already a script running by midnight. I guess it should be pretty straight forward to add some lines of code to store this value in a database or a trend before resetting the value to 0 at midnight. Here are my short comings of LUA programming. How to store data and how to retrieve them later.
I guess (?) that I would only need to register one value per day (per power tag) to get a overall consumption per day? (Regular trends runs as usual).
I see this thread have similarities: https://forum.logicmachine.net/showthrea...ght=trends
JACUZZI
