Mosaic Widget
is it possible to do scene selector with feedback of highlighted button in mosaic visualisation? Something like attached image?
Right now there is no direct way to do it, widget objects have only a bit status. Our scenes can be triggered from a bit object but how do you know if a scene is still active? You could monitor all status objects and update it via a script.
(09.01.2023, 13:43)Daniel Wrote: Right now there is no direct way to do it, widget objects have only a bit status. Our scenes can be triggered from a bit object but how do you know if a scene is still active? You could monitor all status objects and update it via a script.
I´m using scene to select which adress is send to the bus on event and the feedback in visu would be fine.
select=grp.getvalue("32/1/3")
if (select == 0)
  then
elseif (select == 1)
  then
  grp.write("1/0/1", event.getvalue())
elseif (select == 2)
  then
  grp.write("1/0/2", event.getvalue())
elseif (select == 3)
  then
You can make 3 bit objects and on press of one to true you trigger your first scene and write false to other two. Do the same with all three. 3 event scripts and you done.
