Homekit app
i can't control my umidity sensors because home kit wants "scale" datatypes instead my sensors want "byte floating", how could i resolve the issue?? TNX in advance
.pdf   BX-TE_TU-Manuale-Tecnico.pdf (Size: 2.16 MB / Downloads: 6)
(07.07.2024, 09:09)arturfra Wrote: Hi,
You need to create an event script for conversion using a virtual object.
tnx for reply, could you post an example ??
Try something like this:
Consider 1/1/1 the umidity value and 32/0/0 the virtual object for home kit
Event script on 1/1/1
Value = event.getvalue()
grp.update('32/0/0',(math.modf(Value)),dt.scale)
tnx indeed ! It works...
for reading the values OK but now i've to write the desidered humidity value and i've to convert from scale to floating byte, the opposite.. how i should go forward ? Tnx
i solved:
grp.update('2/0/9',(math.modf(Value)),dt.float16)
After pairing Homekit-app with Apple Homekit, Apple Homekit writes that this bridge is not certified to use with Apple Homekit. Not that it matter - it works perfectly well. Just curious if this is a bug in my setup or it's the way it supposed to be.
It it supposed to be like this, we are not planning to go trough certification.
What´s in the new update 20241009?
Some minor internal changes. No functional changes.
do you plan to add door but with toggle function. most of our installation are made with only knx delayed output (pulse) for control, and a contactor on input device. It is the most common use for controlling easily a door. this function is on other controller like jeedom, has, confortclick... should be great to have it also (only to variable control toggle and feedback)
SE ECO EXPERT
Hi.
I've set up my phone (Android) with the Google Home app, and with the connection in the LM app (old) I can control every object without being on the WiFi. But when I set up my girlfriends iPhone with the Apple Home Kit and the same LM app the Apple Home objects says "No repsons" and are NOT controllable as soon as I turn off the WiFi.
Should this be a feature or is it purhaps just Apple that handles it this way.
When WiFi is off, I am still able (via my GFs iPhone) to use the Mosaic app on the LM app, and control the object, but again; all the object in the Apple Home app is not controllable.
Thanks a lot Smile
Google home works trough cloud where Homekit works locally. For it to work remotely you will need apple TV or Apple HomePod.
