MQTT Broker Project with 2024 FW Problem
I attached an old LM project backup which was working as MQTT Broker. I can reach and control the topics via MQTT Explorer. After I upgraded to 2024 fw, i can't see the topics via MQTT Explorer.
I simply created a username and password in the MQTT Broker app. I created a resident script shown below with name MQTT Broker with zero time and i used same username and password in the script which is created in Broker app. It was working but it's not working with 2024 FW as i said before. I can't see the topics via MQTT explorer now.
Can you check script or attached project and tell why it's not working with 2024 FW.
Thx
if not broker then   broker = 'localhost'   function multiply(mult)     return function(value)       local num = tonumber(value)       if num then         return num * mult       else         return value       end     end   end   -- topic to object map   mqtt_to_object = {     ['Magaza1/Sicaklik'] = '1/1/1',     ['Magaza1/Set_Deger'] = '1/1/2',     ['Magaza1/Klima_OnOff'] = '1/1/3',     ['Magaza1/Fan_Hizi'] = '1/1/4',     ['Magaza1/Klima_Mod'] = '1/1/5',     ['Magaza2/Sicaklik'] = '1/1/6',     ['Magaza2/Set_Deger'] = '1/1/7',     ['Magaza2/Klima_OnOff'] = '1/1/8',     ['Magaza2/Fan_Hizi'] = '1/1/9',     ['Magaza2/Klima_Mod'] = '1/1/10',   }   -- object to topic map   object_to_mqtt = {     ['1/1/1'] = 'Magaza1/Sicaklik',     ['1/1/2'] = 'Magaza1/Set_Deger',     ['1/1/3'] = 'Magaza1/Klima_OnOff',     ['1/1/4'] = 'Magaza1/Fan_Hizi',     ['1/1/5'] = 'Magaza1/Klima_Mod',     ['1/1/6'] = 'Magaza2/Sicaklik',     ['1/1/7'] = 'Magaza2/Set_Deger',     ['1/1/8'] = 'Magaza2/Klima_OnOff',     ['1/1/9'] = 'Magaza2/Fan_Hizi',     ['1/1/10'] = 'Magaza2/Klima_Mod',   }     mqtt_to_object_conv = {}   datatypes = {}   grp.sender = 'mq'   require('socket')   for addr, _ in pairs(object_to_mqtt) do     local obj = grp.find(addr)     if obj then       datatypes[ addr ] = obj.datatype     end   end   mclient = require('mosquitto').new()   mclient.ON_CONNECT = function(res, ...)     log('mqtt connect status', res, ...)     if res then       for topic, _ in pairs(mqtt_to_object) do         mclient:subscribe(topic)       end     else       mclient:disconnect()     end   end   mclient.ON_MESSAGE = function(mid, topic, payload)     local addr = mqtt_to_object[ topic ]     if addr then       local fn = mqtt_to_object_conv[ topic ]       if fn then         payload = fn(payload)       end       grp.write(addr, payload)     end   end   mclient.ON_DISCONNECT = function(...)     log('mqtt disconnect', ...)     mclientfd = nil   end   function mconnect()     local fd     mclient:login_set('sonaotomasyon', 'sonaotomasyon')     mclient:connect(broker)     fd = mclient:socket()     -- fd ref is valid     if fd then       mclientfd = fd     end   end   mconnect()   function publishvalue(event)     -- message from us or client is not connected     if event.sender == 'mq' or not mclientfd then       return     end     local addr = event.dst     local dpt = datatypes[ addr ]     local topic = object_to_mqtt[ addr ]     -- unknown object     if not dpt or not topic then       return     end     local value = busdatatype.decode(event.datahex, dpt)     if value ~= nil then       if type(value) == 'boolean' then         value = value and 1 or 0       end       mclient:publish(topic, tostring(value))     end   end   lbclient = require('localbus').new(1)   lbclient:sethandler('groupwrite', publishvalue)   lbclientfd = socket.fdmaskset(lbclient:getfd(), 'r')   -- run timer every 5 seconds   timer = require('timerfd').new(5)   timerfd = socket.fdmaskset(timer:getfd(), 'r') end -- mqtt connected if mclientfd then   mclientfdset = socket.fdmaskset(mclientfd, mclient:want_write() and 'rw' or 'r')   res, lbclientstat, timerstat, mclientstat =       socket.selectfds(10, lbclientfd, timerfd, mclientfdset) -- mqtt not connected else   res, lbclientstat, timerstat =     socket.selectfds(10, lbclientfd, timerfd) end if mclientfd and mclientstat then   if socket.fdmaskread(mclientstat) then     mclient:loop_read()   end   if socket.fdmaskwrite(mclientstat) then     mclient:loop_write()   end end if lbclientstat then   lbclient:step() end if timerstat then   -- clear armed timer   timer:read()   if mclientfd then     mclient:loop_misc()   else     mconnect()   end end
.zip   Project-LogicMachine-2024.09.19-18.14.zip (Size: 129.15 KB / Downloads: 6)
Why don't you use MQTT Client app, it is fully working and your setup will be finished in seconds.
https://forum.logicmachine.net/showthread.php?tid=5609
Hi Daniel,
We have both MQTT Client and MQTT Broker LM's in this project. LM which is used to MQTT Client has less point and we can use it MQTT client app. But in MQTT Broker LM, we have lots of points. To use copy paste function is from excel file much more easy. Therefore we need use resident script in MQTT Broker LM.
Can you check the related script or backup with 2024 fw please which is shared in first post.
Thx
MQTT Broker has no points it is just a messenger between clients. The script you are sharing is MQTT client.
Post a screenshot of your broken configuration. In MQTT Explorer you need to use the same authentication data as in the script.
Topics won't be created until the mapped object is changed.
H,
I am sharing 3 screenshots. Initial screen of MQTT Explorer, connected  screen of MQTT Exporer, MQTT Broker app screenshot.
Try changing object value and the topic will appear in MQTT Explorer.
If you want to keep last topic values for other clients then you need to enable retain flag for messages. To do this replace last line in publishvalue:
With this:
mclient:publish(topic, tostring(value), 0, true)
Note that LM MQTT broker does not have any persistence. If the broker is restarted then retained topics are lost until new value is published.
Additionally you can modify the script to publish all mapped values after a connection to broker is established. Replace mclient.ON_CONNECT with this:
  mclient.ON_CONNECT = function(res, ...)     log('mqtt connect status', res, ...)     if res then       for addr, topic in pairs(object_to_mqtt) do         local value = grp.getvalue(addr)         if value ~= nil then           if type(value) == 'boolean' then             value = value and 1 or 0           end           mclient:publish(topic, tostring(value), 0, true)         end       end       for topic, _ in pairs(mqtt_to_object) do         mclient:subscribe(topic)       end     else       mclient:disconnect()     end   end
Thx for your support. It's working wery well now.
Regards
