Block Auto-size for iframe?
Hi.
Is there possible to block the auto-size setting for iframes in visualisation, tried using some additional CSS an additional classes but no success.
.iframeSpotRing {   height: 670px;                  overflow-y: auto;            /* for adding scrollbar if conent more then 670px */   transform: none !important;  /* block autosize */   width: 100% !important;        pointer-events: all !important; }
Can you explain your use case? transform is applied to the parent plan container element so resetting transform of the iframe won't change anything.
(14.04.2025, 07:03)admin Wrote: Can you explain your use case? transform is applied to the parent plan container element so resetting transform of the iframe won't change anything.
I have set to auto-size in the visu settings.  But for a specific iframe thats open in one plan, I would like to not have auto-size, is this possible?
Because the iframe is for a smaler size than the actual plan thats supose to be shown here, so I want to be able to scroll down inside the iframe. But when tha auto-size is on the view inside the iframe gets auto scaled and result in too small view.
Hope I get the explanation good enough
