Tag triggered script but only on value change
is it possible to trigger an event script based on tag objects but only if the value of that single object is changed?
for example, I have some objects with cyclic send and I want to trigger the script only when the value change
thank you
Use this:
key = 'prev_value_' .. event.dstraw
value = event.getvalue()
prev = storage.get(key)
if value == prev then
  return
storage.set(key, value)
-- put script here
Thank you, works like a charm
