cURL to LUA to set Dahua Camera parameters
Hello! I am trying to send a curl command to a Dahua camera from LM. I have successfully tested the direct cURL command and it works as expected and we avoided extra parameter for 'globoff'. But we have difficulties in translating that into LUA language. I am trying to achieve video enable/disable by simple on-off button in the visualization so thought of using if-else statement. Would something like this work?
Here is the cURL link
curl --digest -u "admin:xxxxxx" "http://10.0.100.10/cgi-bin/configManager.cgi?action=setConfig&Encode%5b0%5d.MainFormat%5b0%5d.VideoEnable=true&Encode%5b0%5d.ExtraFormat%5b0%5d.VideoEnable=true"
Here is a code adapted from Hikvision relay thread. Not sure if I can use PUT method in our case.
url = 'http://admin:xxxxxx@10.0.100.10/cgi-bin/' local skthttp = require('socket.http') local skturl = require('socket.url') local ltn12 = require('ltn12') local md5sum = require('encdec').md5 local value = event.getvalue() local hash = function(...)   return md5sum(table.concat({...}, ':')) end local parse_header = function(header)   local result = {}   for key, value in (header .. ','):gmatch('(%w+)=(.-),') do     if value:sub(1, 1) == '"' then -- strip quotes       result[ key:lower() ] = value:sub(2, -2)     else       result[ key:lower() ] = value     end   end   return result end local make_digest_header = function(headers)   local digest = {}   for _, header in ipairs(headers) do     if not header.unquote then       header[ 2 ] = '"' .. header[ 2 ] .. '"'     end     digest[ #digest + 1 ] = header[ 1 ] .. '=' .. header[ 2 ]   end   return 'Digest ' .. table.concat(digest, ', ') end local _request = function(req)   if not req.url then     return nil, 'missing url'   end   local url = skturl.parse(req.url)   local user, password = url.user, url.password   if not user or not password then     return nil, 'missing credentials in url'   end   url.user, url.password, url.authority, url.userinfo = nil, nil, nil, nil   req.url = skturl.build(url)   local source   if req.source then     local chunks = {}     local capture = function(chunk)       if chunk then         chunks[ #chunks + 1 ] = chunk       end       return chunk     end     local chunk_id = 0     source = function()       chunk_id = chunk_id + 1       return chunks[ chunk_id ]     end     req.source = ltn12.source.chain(req.source, capture)   end   local body, code, hdrs = skthttp.request(req)   if code == 401 and hdrs['www-authenticate'] then     local ht = parse_header(hdrs['www-authenticate'])     if not ht.realm or not ht.nonce then       return nil, 'missing realm/nonce from response'     end     if ht.qop ~= 'auth' then       return nil, 'unsupported qop ' .. tostring(ht.qop)     end     if ht.algorithm and ht.algorithm:lower() ~= 'md5' then       return nil, 'unsupported algo ' .. tostring(ht.algorithm)     end     local nc = '00000001'     local cnonce = string.format('%08x', os.time())     local uri = skturl.build({ path = url.path, query = url.query })     local method = req.method or 'GET'     local response = hash(       hash(user, ht.realm, password),       ht.nonce,       nc,       cnonce,       'auth',       hash(method, uri)     )     req.headers = req.headers or {}     local auth = {       { 'username', user },       { 'realm', ht.realm },       { 'nonce', ht.nonce },       { 'uri', uri },       { 'cnonce', cnonce },       { 'nc', nc, unquote = true },       { 'qop', 'auth' },       { 'algorithm', 'MD5' },       { 'response', response },     }     if ht.opaque then       table.insert(auth, { 'opaque', ht.opaque })     end     req.headers.authorization = make_digest_header(auth)     if not req.headers.cookie and hdrs['set-cookie'] then       -- not really correct but enough for httpbin       local cookie = (hdrs['set-cookie'] .. ';'):match('(.-=.-)[;,]')       if cookie then         req.headers.cookie = '$Version: 0; ' .. cookie .. ';'       end     end     if req.source then       req.source = source     end     body, code, hdrs = skthttp.request(req)   end   return body, code, hdrs end local request = function(url)   local t = type(url)   if t == 'table' then     return _request(table.clone(url))   elseif t == 'string' then     local req = {}     local _, code, headers = _request({ url = url, sink = ltn12.sink.table(req) })     return table.concat(req), code, headers   end end if (value == true) then res, err, hdrs = request({   url = url,   method = 'PUT',   body = 'configManager.cgi?action=setConfig&Encode%5b0%5d.MainFormat%5b0%5d.VideoEnable=true&Encode%5b0%5d.ExtraFormat%5b0%5d.VideoEnable=true' }) else res, err, hdrs = request({   url = url,   method = 'PUT',   body = 'configManager.cgi?action=setConfig&Encode%5b0%5d.MainFormat%5b0%5d.VideoEnable=false&Encode%5b0%5d.ExtraFormat%5b0%5d.VideoEnable=false' }) end log(res, err, hdrs)
Method should be set to GET. What do you get in Logs after sending the request?
(7 hours ago)admin Wrote: Method should be set to GET. What do you get in Logs after sending the request?
With the method set to GET it would log:
* arg: 1   * string: Error Bad Request! * arg: 2   * number: 400 * arg: 3   * table:    ["content-length"]     * string: 21    ["content-type"]     * string: text/plain;charset=utf-8    ["connection"]     * string: close
Which is simply bad request. Can I force the full url from beginning and specify url_on and url_off arguments instead of adding the body inside the function?
UPDATED while testing GET:
- by specifying the full size url_on and url_off it seems to be working with an else-if statement.
url_on = 'http://admin:xxxxxx@10.0.100.10/cgi-bin/configManager.cgi?action=setConfig&Encode%5b0%5d.MainFormat%5b0%5d.VideoEnable=true&Encode%5b0%5d.ExtraFormat%5b0%5d.VideoEnable=true' --skipped the middle part if (value == true) then res, err, hdrs = request({   url = url_on, }) else res, err, hdrs = request({   url = url_off, }) end
