Widget Centering | VISU
I have a question regarding New Visu.
The visualisation will be used mainly on a mobile phone (Tile view only).
Is it possible to center the widgets on the screen, or make them automatically scale to the phone’s screen width?
Custom widget size:320x430, 3x4
Switch widget size: 3x1
Or I just need to add some CSS or JS to achieve this?
I also have a question regarding “Tile view width” in Admin Visu. Does this parameter have any impact on the final appearance of the application?
Thanks in advance!
BG
In General Settings you can define tile width and then tile view on mobile will stay always on the seize selected. The widget you use is 3 tiles.
(8 hours ago)Daniel Wrote: In General Settings you can define tile width and then tile view on mobile will stay always on the seize selected. The widget you use is 3 tiles.
In general settings I only have this...
Update Visu to latest version.
(7 hours ago)Daniel Wrote: Update Visu to latest version.
It works!
Thank You!
