I thought I'd share this work in progress. I am an amateur both in Lua and in KNX... so take with a huge grain of salt.
All it does is open a socket to a defined IP and Port and send a telnet command... then add an "Enter"... then wait for an answer. It closes right after that, as the Pioneer does not like more than one telnet connection at a time and I don't want to hog the port.
Copy this code into a user library. I called mine user.telnet
and put this code into a separate user.script. I called mine user.pioneer
All it does is define a huge amount of variables with the correct telnet commands for the Pioneer avr 529 I have. Change, reduce as needed. There are most probably errors in the codes, as these where copied and pasted from around the web.
Lastly call the above user libraries from a KNX object like the following:
The 11/2/2 Object is the status object, that gets written with the return value of soundonoff.
1234567891011121314151617181920212223242526272829303132333435363738394041424344454647484950515253545556575859606162636465
--Sends a single telnet command to a host and port
--it returns one line answer
function telnetsend(host, port, command)
nextline = '\r\n'
local socket = require("socket")
local tcp = assert(socket.tcp())
res, err = tcp:connect(host, port)
res, err = tcp:send(command .. nextline)
local answer = tcp:receive('*l')
tcp:close()
return answer
--Sets the volume to a numeric value
--takes into account, that Pioneer increments the volume in
--2 step intervals. Takes a host ip and port as input.
function setvolume(host, port, volumelevel)
local currentvolume = getvolume(host, port)
if volumelevel > currentvolume then
for i = currentvolume, volumelevel -1, 2 do
telnetsend(host,port,VOLUME_UP)
for i = volumelevel, currentvolume-1, 2 do
telnetsend(host,port,VOLUME_DOWN)
return currentvolume
--Returns the current volume
function getvolume(host, port)
local currentvolume = tonumber(string.sub(telnetsend(host,port,VOLUME_QUERY), 5))
--Turns reciever on off
function soundonoff(host, port, onoff)
if onoff == true then
telnetsend(host,port,POWER_ON)
local status = telnetsend(host,port,POWER_QUERY)
if status == POWER_ONSTATE then
return true
alert("Could not turn on sound")
telnetsend(host,port,POWER_OFF)
if status == POWER_OFFSTATE then
return false
alert("Could not turn off sound")
endand put this code into a separate user.script. I called mine user.pioneer
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293949596979899100101102103104105106107108109110111112113114115116117118119120121122123124125126127128129130131132133134135136137138139140141142143144145146147148149150151152153154155156157158159160161162163164165166167168169170171172173174175176177178179180181182183184185186187188189190191192193194195196197198199200201202203204205206207208209210211212213214215
-- Main zone
POWER_ON="PO"
POWER_OFF="PF"
POWER_QUERY="?P"
POWER_ONSTATE="PWR2"
POWER_OFFSTATE="PWR0"
-- Volume
VOLUME_UP="VU"
VOLUME_DOWN="VD"
VOLUME_QUERY="?V"
VOLUME_SET="VL"
-- Mute
MUTE= "MO"
UNMUTE= "MF"
MUTE_QUERY="?M"
-- Source / Input channel
SOURCE_QUERY="?F"
SOURCE_UP= "FU"
SOURCE_DOWN="FD"
SOURCE_SET= "%02dFN"
SOURCE_DVD= "04FN"
SOURCE_BD= "25FN"
SOURCE_TVSAT="05FN"
SOURCE_DVR_BDR="15FN"
SOURCE_VIDEO1="10FN"
SOURCE_VIDEO2="14FN"
SOURCE_HDMI1="19FN"
SOURCE_HDMI2="20FN"
SOURCE_HDMI3="21FN"
SOURCE_HDMI4="22FN"
SOURCE_HDMI5="23FN"
SOURCE_HMG= "26FN"
SOURCE_IPOD_USB="17FN"
SOURCE_XMRADIO="18FN"
SOURCE_CD="01FN"
SOURCE_CDR_TAPE="03FN"
SOURCE_TUNER="02FN"
SOURCE_PHONO="00FN"
SOURCE_MULTICH_IN="12FN"
SOURCE_ADAPTER_PORT="33FN"
SOURCE_HDMI_CYCL="31FN"
-- Listening mode
LISTENING_MODE="%04dSR"
LISTENING_MODE_QUERY="?L"
-- tone control
TONE_ON="TO1"
TONE_BYPASS="TO0"
TONE_QUERY="?TO"
-- bass control
BASS_INCREMENT="BI"
BASS_DECREMENT="BD"
BASS_QUERY="?BA"
-- treble control
TREBLE_INCREMENT="TI"
TREBLE_DECREMENT="TD"
TREBLE_QUERY="?TR"
-- Speaker configuration
SPEAKERS="%01dSPK"
SPEAKERS_OFF="0SPK"
SPEAKERS_A="1SPK"
SPEAKERS_B="2SPK"
SPEAKERS_A_B="3SPK"
-- HDMI outputs configuration
HDMI_OUTPUT="%01dHO"
HDMI_OUT_ALL="0HO"
HDMI_OUT_1="1HO"
HDMI_OUT_2="2HO"
-- HDMI audio configuration
HDMI_AUDIO_AMP="0HA"
HDMI_AUDIO_THROUGH="1HA"
-- PQLS setting
PQLS_OFF="0PQ"
PQLS_AUTO="1PQ"
-- Zone 2 control
ZONE2_POWER_ON= "APO"
ZONE2_POWER_OFF="APF"
ZONE2_POWER_QUERY="?AP"
ZONE2_INPUT="%02dZS"
ZONE2_INPUT_DVD="04ZS"
ZONE2_INPUT_TV_SAT="05ZS"
ZONE2_INPUT_DVR_BDR="15ZS"
ZONE2_INPUT_VIDEO1="10ZS"
ZONE2_INPUT_VIDEO2="14ZS"
ZONE2_INPUT_HMG="26ZS"
ZONE2_INPUT_IPOD="17ZS"
ZONE2_INPUT_XMRADIO="18ZS"
ZONE2_INPUT_CD= "01ZS"
ZONE2_INPUT_CDR_TAPE="03ZS"
ZONE2_INPUT_TUNER="02ZS"
ZONE2_INPUT_ADAPTER="33ZS"
ZONE2_INPUT_SIRIUS="27ZS"
ZONE2_INPUT_QUERY="?ZS"
ZONE2_VOLUME_UP="ZU"
ZONE2_VOLUME_DOWN="ZD"
ZONE2_VOLUME= "%02ZV", "ZV"
ZONE2_VOLUME_QUERY="?ZV"
ZONE2_MUTE= "Z2MO"
ZONE2_UNMUTE= "Z2MF"
ZONE2_MUTE_QUERY="?Z2M"
-- zone 3 control
ZONE3_POWER_ON= "BPO"
ZONE3_POWER_OFF="BPF"
ZONE3_POWER_QUERY="?BP"
ZONE3_INPUT="%02dZT"
ZONE3_INPUT_DVD="04ZT"
ZONE3_INPUT_TV_SAT="05ZT"
ZONE3_INPUT_DVR_BDR="15ZT"
ZONE3_INPUT_VIDEO1="10ZT"
ZONE3_INPUT_VIDEO2="14ZT"
ZONE3_INPUT_HMG="26ZT"
ZONE3_INPUT_IPOD="17ZT"
ZONE3_INPUT_XMRADIO="18ZT"
ZONE3_INPUT_CD= "01ZT"
ZONE3_INPUT_CDR_TAPE="03ZT"
ZONE3_INPUT_TUNER="02ZT"
ZONE3_INPUT_ADAPTER="33ZT"
ZONE3_INPUT_SIRIUS="27ZT"
ZONE3_INPUT_QUERY="?ZT"
ZONE3_VOLUME_UP="YU"
ZONE3_VOLUME_DOWN="YD"
ZONE3_VOLUME= "%02YV"
ZONE3_VOLUME_QUERY="?YV"
ZONE3_MUTE= "Z3MO"
ZONE3_UNMUTE= "Z3MF"
ZONE3_MUTE_QUERY="?Z3M"
-- radio tuner
TUNER_FREQ_INCREMENT="TFI"
TUNER_FREQ_DECREMENT="TFD"
TUNER_FREQ_QUERY_AM="?FR"
TUNER_FREQ_QUERY_FM="?FR"
TUNER_BAND= "TB"
TUNER_PRESET= "%01dTP"
TUNER_CLASS= "TC"
TUNER_PRESET_INCREMENT="TPI"
TUNER_PRESET_DECREMENT="TPD"
TUNER_PRESET_QUERY="?TP"
-- iPod control
IPOD_PLAY= "00IP"
IPOD_PAUSE= "01IP"
IPOD_STOP= "02IP"
IPOD_PREVIOS= "03IP"
IPOD_NEXT= "04IP"
IPOD_REV= "05IP"
IPOD_FWD= "06IP"
IPOD_REPEAT= "07IP"
IPOD_SHUFFLE= "08IP"
IPOD_DISPLAY= "09IP"
IPOD_CONTROL= "10IP"
IPOD_CURSOR_UP= "13IP"
IPOD_CURSOR_DOWN="14IP"
IPOD_CURSOR_LEFT="15IP"
IPOD_CURSOR_RIGHT="16IP"
IPOD_ENTER= "17IP"
IPOD_RETURN= "18IP"
IPOD_TOP_MENU= "19IP"
IPOD_KEY_OFF= "KOF"
ADAPTER_PLAY_PAUSE="20BT"
ADAPTER_PLAY="10BT"
ADAPTER_PAUSE="11BT"
ADAPTER_STOP="12BT"
ADAPTER_PREVIOUS="13BT"
ADAPTER_NEXT="14BT"
ADAPTER_REV="15BT"
ADAPTER_FWD="16BT"
-- Home Media Gateway (HMG) control
HMG_NUMKEY="%02dNW"
HMG_NUMKEY_0="00NW"
HMG_NUMKEY_1="01NW"
HMG_NUMKEY_2="02NW"
HMG_NUMKEY_3="03NW"
HMG_NUMKEY_4="04NW"
HMG_NUMKEY_5="05NW"
HMG_NUMKEY_6="06NW"
HMG_NUMKEY_7="07NW"
HMG_NUMKEY_8="08NW"
HMG_NUMKEY_9="09NW"
HMG_PLAY="10NW"
HMG_PAUSE="11NW"
HMG_PREV="12NW"
HMG_NEXT="13NW"
HMG_DISPLAY="18NW"
HMG_STOP="20NW"
HMG_UP= "26NW"
HMG_DOWN="27NW"
HMG_RIGHT="28NW"
HMG_LEFT="29NW"
HMG_ENTER="30NW"
HMG_RETURN="31NW"
HMG_PROGRAM="32NW"
HMG_CLEAR="33NW"
HMG_REPEAT="34NW"
HMG_RANDOM="35NW"
HMG_MENU="36NW"
HMG_EDIT="37NW"
HMG_CLASS="38NW"
-- display info text
DISPLAY_INFO_QUERY="?FL"Lastly call the above user libraries from a KNX object like the following:
require('user.telnet')
require('user.pioneer')
--we write the returned set volume to the status object
grp.write('11/2/2', soundonoff('192.168.0.24',8102,event.getvalue()))The 11/2/2 Object is the status object, that gets written with the return value of soundonoff.
