AXIS D2050-VE Radar control
Hello!
I have this axis product in one project.
These radars are great for perimeter protection as they help to reduce fake triggers from IP cameras.
Also, when linked with PTZ cameras - they control PTZ to accurately track intruders with zoomed-in vision.
Everything would be fine, but PTZ tracking service is running on windows machine and i would like to control from LM when this service is available.
I thought that disabling radar while not needed would be easier task than stopping service on windows machine.
I need to HTTP POST JSON data with digest auth, and don't know how to assemble this request.
I successfully did it with basic auth, but i need digest, as 'radar autotracking for PTZ' needs this level of authorization.
Could someone help me?
Basic auth code is here:
function post(url, body)   local ltn12 = require('ltn12')   local http = require('socket.http')   local sink = {}   local res, err = http.request({     url = url,     method = 'POST',     headers = {       ['Authorization'] = 'Basic '..(mime.b64('<username>:<password>')),       ['Content-Length'] = #body,       ['Content-Type'] = 'application/json',     },     sink = ltn12.sink.table(sink),     source = ltn12.source.string(body),   })   if res then     return table.concat(sink)   else     return nil, err   end end require('json') url = 'http://<IPADDRESS>/axis-cgi/radar/control.cgi' body = json.encode({ apiVersion = '1.3',context =  '<client context>',method = 'setEnabled',params = {enabled = false}}) --res, err = post(url, body) --log(res, err)
I need this to work with digest.
Thanks!
Try digest code from this post:
https://forum.logicmachine.net/showthrea...64#pid9364
(09.05.2020, 09:22)Erwin van der Zwart Wrote: Try digest code from this post:
Thank You, I tried this, but cannot manage on how to change method to POST and add json body to it Sad
If i change method it tells me i'm giving wrong credentials.
