For anyone it might help I wanted to share some scripts to control Yamaha R-N301 HiFi Receiver and automate a Public Announcement system using SNOM PA1.
The main objective is to make the necessary settings (input, volume etc) on R-N301 when PA receives a call and return to previous state when the call ends.
I am basically new to scripting so any suggestions are welcome.
I have created the following objects on logic machine
![[Image: MGoq9n0.png]](http://i.imgur.com/MGoq9n0.png)
Using Snom PA1 Action URL feature and Logic Machine remote services to update object 2/6/11 when a call is connected or disconnects.
![[Image: 5yya0fY.png]](http://i.imgur.com/5yya0fY.png)
On Connected : http://remote:remote@192.168.16.10/cgi-bin/scada-remote/request.cgi?m=json&r=grp&fn=write&alias=2/6/11&value=true
On Disconnected: http://remote:remote@192.168.16.10/cgi-bin/scada-remote/request.cgi?m=json&r=grp&fn=write&alias=2/6/11&value=false
Scripts
1. Yamaha R-N301 control and feedback function
2. Object 2/6/11 event script
Scripts
Basic control and feedback function for Yamaha R-N301 amplifier
Input cmd
Get feedback : GET eg rn301('GET', '<Main_Zone><Basic_Status>GetParam</Basic_Status></Main_Zone>')
Send command : PUT eg rn301('PUT', '<System><Power_Control><Power>Standby</Power></Power_Control></System>')
Input param
Update feedback objects : <Main_Zone><Basic_Status>GetParam</Basic_Status></Main_Zone>
Power on : <System><Power_Control><Power>On</Power></Power_Control></System>
Standby : <System><Power_Control><Power>Standby</Power></Power_Control></System>
Mute On : <Main_Zone><Volume><Mute>On</Mute></Volume></Main_Zone>
Mute Off : <Main_Zone><Volume><Mute>Off</Mute></Volume></Main_Zone>
Volume (0-100) : <Main_Zone><Volume><Lvl><Val>50</Val><Exp>0</Exp><Unit></Unit></Lvl></Volume></Main_Zone>
Input : <Main_Zone><Input><Input_Sel>LINE1</Input_Sel></Input></Main_Zone>
Returns table with status feedback (Result, Rescode, Power, Volume, Mute, Input)
function rn301(cmd, param)
require 'socket.http'
-- Create HTTP post body
local request_body = '<?xml version="1.0" encoding="utf-8"?>' ..
'<YAMAHA_AV cmd="' .. cmd.. '">' ..
(param or '') ..
'</YAMAHA_AV>'
local response_body = { }
local status_tbl = { }
-- Send command to amplifier
local result, code = socket.http.request
url = 'http://192.168.16.22/YamahaRemoteControl/ctrl',
method = 'POST',
headers =
["Content-Type"] = "application/x-www-form-urlencoded",
["Content-Length"] = request_body:len(),
source = ltn12.source.string(request_body),
sink = ltn12.sink.table(response_body),
-- Check responce from amplifier
if result and code==200 then
status_tbl['Result']=result
status_tbl['ResCode']=code
if cmd == 'GET' then
if type(response_body) == "table" then
response_body=table.concat(response_body)
power=string.sub(string.match(response_body,"<Power>%a+</Power>"), 8, -9)
status_tbl['Power']=power
-- Manipulate and update power feedback object
if power=='On' then
grp.write('2/6/51', true)
grp.write('2/6/51', false)
volume=tonumber(string.sub(string.match(response_body,"<Val>%d+</Val>"), 6, -7))
status_tbl['Volume']=volume
-- Update volume feedback object
grp.write('2/6/53', volume)
mute=string.sub(string.match(response_body,"<Mute>%a+</Mute>"), 7, -8)
status_tbl['Mute']=mute
-- Manipulate and update mute feedback object
if mute == 'On' then
grp.write('2/6/52', true)
grp.write('2/6/52', false)
input=string.sub(string.match(response_body,"<Input_Sel>.*</Input_Sel>"), 12, -13)
status_tbl['Input']=input
-- Update input feedback object
grp.write('2/6/54', input)
alert('HTTP Request Error: Response is empty or unknown')
alert('HTTP Request Error: ' .. code)
return status_tbl
end2. Object 2/6/11 event script
value=event.getvalue()
-- Update feedback objects
yamaha=grp.getvalue('2/6/51')
-- 1st case: Call Connected and R-N301 already On
-- Store current power status, input and volume level
-- Set Input to Line1(PA system), Volume to 50 and make sure mute is off
if value and yamaha then
storage.set('yamaha_pwr',yamaha)
prv_volume=grp.getvalue('2/6/53')
storage.set('yamaha_volume',prv_volume)
prv_input=grp.getvalue('2/6/54')
storage.set('yamaha_input',prv_input)
rn301('PUT', '<Main_Zone><Volume><Mute>Off</Mute></Volume></Main_Zone>')
rn301('PUT', '<Main_Zone><Volume><Lvl><Val>50</Val><Exp>0</Exp><Unit></Unit></Lvl></Volume></Main_Zone>')
rn301('PUT', '<Main_Zone><Input><Input_Sel>LINE1</Input_Sel></Input></Main_Zone>')
-- 2nd case: Call Connected and R-N301 already on Standby
-- Power On R-N301, set Input to Line1(PA system), Volume to 50 and make sure mute is off
elseif value and not (yamaha) then
rn301('PUT', '<System><Power_Control><Power>On</Power></Power_Control></System>')
-- 3rd case: Call Disconnects and R-N301 was On before call
-- Set Input, Volume to previous state and make sure Mute is off
elseif (not value) and storage.get('yamaha_pwr',0) then
prv_volume=storage.get('yamaha_volume',30)
prv_input=storage.get('yamaha_input','CD')
rn301('PUT', '<Main_Zone><Volume><Lvl><Val>' .. prv_volume .. '</Val><Exp>0</Exp><Unit></Unit></Lvl></Volume></Main_Zone>')
rn301('PUT', '<Main_Zone><Input><Input_Sel>' .. prv_input .. '</Input_Sel></Input></Main_Zone>')
-- 4th case: Call Disconnects and R-N301 was Off before call
-- Just make sure Mute is off and then power off
You are right, didn't cross my mind to use string.match because the reply is pretty much static but will be helpfull on futher control.
