BacNetIP - issues
Hi.
I have problem witch BacNet IP client (app). We have to integrate an AHU made by Svegon (GOLD).
Application found a device but if i start looking for data points i have as a result those scenario:
  • application after a few seconds found no data points at all;
  • application keep looking for data points and keep looking, and .... - keep looking endlessly;
  • if i application found data points:
    - can't add (mapping) points as virtual one - crossed out symbol of cloud;- i can't remove already mapped points as virtual one - i have massage - the point no is not existing on this no. of device (BACNET address)- if i can add points - adding points take ages, and can be only not virtual one.
I tried:
  • remove app, and reinstall app again - app after new installation found BacNet device - but data points are already mapped - that same behavior of LM5 with adding points;
  • factory reset of LM5 - installation of app - app after new installation found BacNet device - but data points are already mapped - that same behavior of LM5 with adding points.
I tried web browsers: Chrome, Firefox, Safari.
I tried on LM firmware 2022 RC1, 2022 RC1 and with this one https://dl.openrb.com/lm-22-imx6/lm5m3ex-20221205.img
also witch 20211215.
Any ideas what's going on?
Thanks for help.
This app has its known limitation. It works on very small installations. You better try our original solution
https://openrb.com/logicmachine-as-bacnet-client/
Uninstall the app if you going to use this.
(12.12.2022, 09:44)Daniel Wrote: This app has its known limitation. It works on very small installations.  You better try our original solution
Thanks for quick answer. But i can't.
This is LM5 Lite.
Install the genohm-scada-bacnet.ipk from Extra packages in: Sys Config –> System –> Packages
If you use RC1 22 then take packages from here https://dl.openrb.com/lm-22-imx6/pkg/
(12.12.2022, 09:59)Daniel Wrote: Install the genohm-scada-bacnet.ipk from Extra packages in: Sys Config –> System –> Packages
I did it. Scaning is working well. could you be so polite and tell me how add Bagnet data points to objects?
Thanks again.
You have to use script for this, there are examples in the link I sent you.
(12.12.2022, 10:16)Daniel Wrote: You  have to use script for this, there are examples in the link I sent you.
