03.01.2023, 10:05
script for 4 bit dimming to send command to 1 Byte unsigned integer dimming
4 bit dimming script
03.01.2023, 10:05
03.01.2023, 10:16
Have a look here
https://forum.logicmachine.net/showthrea...27#pid8027
03.01.2023, 13:04
In 2022 RC1 firmware and later you can use an event script with execution mode set to "Last instance only". Change parameters on first three lines as needed.
Code: out = '1/1/2' -- output group address (1 byte scale) |
