tag group write, only different data
I have a script that writes values to a group addresses:
AllStatus = grp.tag('test')
AllStatus:write( true )
I want to write only to that addresses that have different data then the value to write. In this case only write value true to addresses with tag 'test' and value false.
function tagcheckwrite(tag, value)
  local objects = grp.tag(tag)
    if object.data ~= value then
      object:write(value)
tagcheckwrite('test', false)
if you look for the object AllStatus, you'll find it's an array with all object.
You can do a loop on this array and write the value only if it's not the same
Will look something like:
for _, item in ipairs(AllStatus) do
if item.value != newvalue then
grp.write(item.address, newvalue
Edit: Admin send a reply just before my. take his Smile
