Rituals Genie
Here my code to control a Rituals Genie.
add a library
--[[ based on     - https://community.home-assistant.io/t/restful-or-not-rituals-perfume-genie/167112     - fibaro rituals genie quickapp --]] json = require('json') https = require('ssl.https') ltn12 = require('ltn12') escape = require('socket.url').escape -- rituals account ritualsServer = 'https://rituals.sense-company.com' ritualsUserName = 'xxx@xxxxxxxx.nl' ritualsPassword = 'xxxxxxxx' -- hubs hubWoonkamer = 1  -- get from getHubs() -- general debug logging debug = false function debugLog(iLog)     if debug then     log(iLog)   end end   -- general web request function function request(endpoint, data, method)   local url = ritualsServer .. endpoint   local resp = {}   local headers = {     ['Content-Type'] = 'application/json'   }   local source   if data then     method = method or 'POST'     source = ltn12.source.string(data)     headers['Content-Length'] = #data   else     method = 'GET'   end   local res, code = https.request({     url = url,     method = method,     headers = headers,     source = source,     sink = ltn12.sink.table(resp)   })   debugLog(res,code,resp)     if res and code == 200 then     return json.pdecode(table.concat(resp))   else     return res, code   end end -- get account hash function getAccount()   data = '{\"email\": \"' .. ritualsUserName .. '\", \"password\": \"' .. ritualsPassword .. '\"}'   resp = request('/ocapi/login', data, 'POST')   accountHash = resp.account_hash   return accountHash end --getAccount() -- get hub hash function getHubs(iHub)     data = nil     resp = request('/api/account/hubs/'..getAccount(), data, 'GET')   if iHub then       hubHash = resp[iHub].hub.hash       return hubHash   else     debugLog(resp) -- get all hubs   end end --getHubs() --getHubs(hubWoonkamer) -- get hub hash function getHubInfo(iHub)     data = nil     resp = request('/api/account/hub/'..getHubs(iHub), data, 'GET')     debugLog({'power:'..resp.hub.attributes.fanc, 'speed:'..resp.hub.attributes.speedc, 'cardridge:'..resp.hub.sensors.rfidc.title, 'volume:'..resp.hub.sensors.fillc.title}) end --getHubInfo(hubWoonkamer) -- set hub state function setHubState(iHub, iState)     if iState then oState = 1 else oState = 0 end   data = '{\"hub\": \"' .. getHubs(iHub) .. '\",\"json\": {\"attr\": {\"fanc\": \"'..oState..'\"}}}'   resp = request('/api/hub/update/attr', data, 'POST') end --setHubState(hubWoonkamer,true) --setHubState(hubWoonkamer,false) -- set hub speed (1=low, 2=med, 3=high) function setHubSpeed(iHub, iSpeed)   data = '{\"hub\": \"' .. getHubs(iHub) .. '\",\"json\": {\"attr\": {\"speedc\": \"'..iSpeed..'\"}}}'   resp = request('/api/hub/update/attr', data, 'POST') end --setHubSpeed(hubWoonkamer,1) --setHubSpeed(hubWoonkamer,2) --setHubSpeed(hubWoonkamer,3)
use this code for example
require('user.nit_rituals') setHubState(hubWoonkamer,true)
