01.01.2017, 21:44
Happy New Year...
Take the following example, you have a light, its a switch on a motion sensor. You only want to show whether that light is on or not given that this could mess with the motion sensor. The switch widget requires both the on/off and status object.
Another example of where this could be used is with lights that are on a timer. You want to see them but there is no need to change them because they are controlled by an timer.
Thanks,
roger
Happy New Year...
Thanks,
roger
