Could be possible to change objects inside a widget?
Hello, I think that is not possible, but it could be useful:
is there a way to create a dataset of objects that you can select with an index? The purpose is, for example, to make a widget (only one) and switch data in it by changing the index value, doing so you can deduplicate widgets and make faster modifications.
https://forum.logicmachine.net/showthrea...2#pid17512
