AMQP Client example
Thank you for an excellent support forum. I need to integrate my LM5 with Azure IoT Hub, but would prefer AMQP (or RabbitMQ) over REST or MQTT. Could you give an example using a AMQP-based client?
Best regards from
Eilert Bjerkan
Norway
Hi Eilert,
our guys have used before ZeroMQ. It has already binding to LUA. If you want we can prepare the packages.
How I know ZeroMQ can already communicate with Azure IoT Hub, see here:
https://coderead.wordpress.com/2012/10/1...-on-azure/
By the way, why don't you use MQTT?
