Create User with DB
Hi all,
I add a user to the database like this :
    local user = {         name = db:escape(name),         login = db:escape(login),         password = hashpassword(db:escape(login), "123456"),                 homepage = "apps-fcs",                 access_apps = "P",                 access_vis = '',         access_mosaic = "F",         access_schedulers = '',         access_trends = '',                 allow_objects = "",                 active = 1     }          result, err = db:insert('users', user)     io.readproc('/etc/init.d/nginx reload')
The user is added, but when I'm try to connect, I get a 403 error !
any idea ?
thanks
Use webrequest library: https://forum.logicmachine.net/showthread.php?tid=4425
You don't need to escape/has any values.
Hi admin,
I forgot to mention that I was in a .lp file for an app.
Where did the 403 error come from? j
In current firmware you should be able to use webrequest in .lp files.
You have partial apps access set but no ACL for apps provided.
