DALI on LM5 Reactor Dimmer KNX (i.MX6)
I am relatively new to the use of LM, so forgive me for my ignorance.
I managed to connect 1 DALI device to my LM.
I can see the three control objects (On/Off, 4-bit & Scale),
but I can see nowhere any feedback objects.
Are there any?
These are the old generation of DALI which is not evolving as we moved this to our CANx extensions and in there you have everything. This solution works fine but it is very limited. For feedback you will need a script, see this
https://forum.logicmachine.net/showthrea...0#pid17130
(07.03.2025, 12:43)Daniel Wrote: These are the old generation of DALI which is not evolving as we moved this to our CANx extensions and in there you have everything. This solution works fine but it is very limited.  For feedback you will need a script, see this
Is my LM compatible with the CANx extensions?
There are two versions of Reactor dimmer, but most likely you have the KNX version and this will be no then.
(07.03.2025, 15:09)Daniel Wrote: There are two versions of Reactor dimmer, but most likely you have the KNX version and this will be no then.
You are right. There is no CAN terminal on my device.
Is it possible to change the short address of DALI devices?
https://forum.logicmachine.net/showthrea...6#pid35346
