14 byte HEX
I would like to manage the code digit on an access control KEYPAD. When I set the object at 14 byte HEX I can see the digit on the group address list but in the log of the scripting I see only "?????".
In this way I cannot manage the code. How can I solve it please?
Use loghex() to log the value in HEX format.
(19.03.2025, 10:55)admin Wrote: Use loghex() to log the value in HEX format.
Thanks!
Sorry, but why I cannot to use this instruction?
first6 = string.sub(value,1,6)
Sorry, I mean that I would like to keep just the first 6 digit of the value. Hence:
value = event.getvalue()
loghex(value)
log('first6 string is:', prime6)
I tried to convert value "tostring" without success.
What could you suggest please?
Tks.
Try this:
bytes = { value:byte(1, 6) }
code = table.concat(bytes)
log(code)
(19.03.2025, 12:42)admin Wrote: Try this:
log(code)
it does not work because the number result is not correct. I log this follow with loghex(value):
Quote:* arg: 1
  * hexstring [13]: 69 6C 20 6E 75 6D 65 72 6F 20 C3 A8 3A
* arg: 2
  * hexstring [4]: 12 12 12 01
The number I want to take are 121212.
It is consider a table with 2 value?
Try this:
code = lmcore.strtohex(value:sub(1, 3))
log(code)
