01.09.2025, 18:19
After the last update to v20250813, I noticed that the Internal DALI gateway is not working.
Any suggestions on how to troubleshoot that?
Internal DALI gateway not working
01.09.2025, 18:19
02.09.2025, 11:03
02.09.2025, 13:33
We tested it on this LM and it works fine, maybe you installed wrong firmware?
03.09.2025, 13:57
(02.09.2025, 13:33)Daniel Wrote: We tested it on this LM and it works fine, maybe you installed wrong firmware? If I am not mistaken, I installed the correct one.
03.09.2025, 13:59
This is wrong, you need LM5 Lite + Ext (4 or 6 DIN units)
04.09.2025, 14:08
I messed it with my old LM. Is it ok to install the correct version now?
04.09.2025, 17:42
(04.09.2025, 14:08)Daniel Wrote: yes Daniel, I just installed the correct version and everything is back in order. I am not sure how I ended in this mistake, but I suspect something, that I suggest you to investigate. Usually, when I have to update, I check the previous version and then I download and install the appropriate files. Prior to the most recent update, I changed my LM, so I created a backup of all the configurations and then restored it to the new LM. The only bug that could cause this mess, is if the backup/restore process caused the LM to show the wrong version. For me it is solved, so thank you for the help.
Yesterday, 06:51
Backup does not contain this information. It cannot change the firmware version information.
Yesterday, 16:33
